misfire with no check engine light or codes
Old Oct 31, 2007 | 11:54 PM
Thrower20's Avatar
Thrower20
I have a 98' Expy and it is misfiring now at idle and under acceleration. I do not get a check engine light and when I use a code reader, it does not find any codes. 126K on the 5.4L and I have changed the #4 COP twice and the #1 COP once. Original plugs changed at 90K, leaking heater hose over #4 changed 2 years ago and the tranny was serviced 12 months ago.
Any ideas on how to narrow my troubleshooting efforts? The check engine light illuminates on start up. Any ideas on why the check engine light is not functioning? Any ideas would be great, this forum has saved sooo much time and money. All of your thoughts are greatly appreciated.
Rodney
98', 5.4L, 126K, Uni-Filter, Amsoil
3" cat back w/ FlowMaster, Nokian WR
Old Nov 1, 2007 | 06:04 AM
projectSHO89's Avatar
projectSHO89
https://www.ford-trucks.com/forums/s...searchid=68936
Old Nov 2, 2007 | 01:46 AM
Thrower20's Avatar
Thrower20
The link did not connect to another thread.
Rodney
Old Nov 2, 2007 | 07:19 AM
projectSHO89
Rodney
Ack!... Sorry... I was trying to point you towards several of my previous posts that answered your questions.
What I did was enter "MISFIRECNT" into the SEARCH box...
Looks like the forum software only saves the SEARCH results for a short time.... Try that explicit SEARCH to return previous posts.
Steve
Old Nov 3, 2007 | 12:32 AM
mallen88's Avatar
mallen88
I am having a similar problem with a vehicle at work. It misses at idle and under a load. It is an intermittent problem. I replaced the spark plugs and boots and the problem remained. After a little research on the internet I am leaning toward a bad DPFE (differential pressure feedback EGR). I ordered a new one but the part did not show up by the time I got off of work. I am sure that is the problem and I will post back with the results. This is the first time I had this problem. Usually replacing the spark plugs and boots take care of the problem.
Old Nov 3, 2007 | 12:35 AM
Fordlover55's Avatar
Fordlover55
Still kicking!!
My 99, 4.6 was doing the intermittant miss under accelleration. I replaced plugs and wires. Ta Da. No COPS on mine though.
She runs like new again.
Old Nov 3, 2007 | 09:34 AM
ronk1969's Avatar
ronk1969
had same problems with mine. i would replace plugs and would still get misfire. found out that i had a bad coil i also put on a nice set a plug wires and the expy runs like a champ.
Old Nov 3, 2007 | 05:40 PM
Thrower20's Avatar
Thrower20
Thanks for the replies, yesterday I got the enigine light to flash once per second. I got a P0300 code random misfire and in the freeze frame section I got:
Fuel sys 1 - CL; Fuel sys 2 - CL-Fault; Calc Load (%) - 56.08; ECT (F) - 192; STFT B1 (%) - -3.91.
I understand the misfire, which does not help a whole lot, but does anyone understand the freeze frame information and how can I use it.
Thanks,
Rodney
Old Nov 3, 2007 | 10:08 PM
projectSHO89
Where's the rest of the FF data?
What engine is being discussed?
Can your scan tool read the Mode 6 data?
Steve
Old Nov 5, 2007 | 01:54 AM
Thrower20's Avatar
Thrower20
Here's the rest of the data; LTFT B1 (%) - 10.94, STFT B@ (%) - -4.69, LTFT B2 (%) - 10.94, RPM 1987, Vehicle spd 66 mph. This reader can not read mode 6 data. I will check with a neighbor, he might have one that will.
Thanks,
Rodney
Old Nov 5, 2007 | 08:39 PM
mallen88's Avatar
mallen88
Ok got back to work today and the DPFE sensor I ordered showed up. I verified that the misfire was still happening. Of course it was. I installed the DPFE sensor and checked for a misfire-it was gone. The truck ran perfect.
Old Nov 6, 2007 | 07:34 AM
projectSHO89
Chances are, you were getting uncommanded or improperly regulated EGR flow due to that faulty DPFE sensor.
Try not to hijack threads...
Steve
Goof008
Modular V8 (4.6L, 5.4L)
Jan 5, 2017 06:52 AM
obeonec
2004 - 2008 F150
Apr 1, 2015 08:19 AM
CJ2003F250SD
Sep 9, 2014 09:24 PM
jazztone
29
Jul 30, 2014 11:25 PM
PEPpfts
35
Jan 29, 2012 11:53 PM
