Propane Furnace Question.
Old Oct 31, 2007 | 07:29 PM
Bruker's Avatar
Bruker
Question Propane Furnace Question.
The other day I did my normal "clean out the furnace to get it ready for winter" thing and now when it starts up the burners give off an orange tipped flame instead of the normal blue flame. Does this mean I need to adjust the air mix to allow less air or more?
Old Oct 31, 2007 | 07:36 PM
medhvac's Avatar
medhvac
i think you need to check your gas pressure at the gas valve if you know how? i think propane should be 10.5 WC comeing out!
Old Oct 31, 2007 | 07:51 PM
Buck 1's Avatar
Buck 1
The orange tip flame indicates that the gas/air mixture has to be adjusted. I believe that with the orange tip the mixture is too lean, but a call to your propane company should give you the info you need.
Old Oct 31, 2007 | 08:20 PM
GLR's Avatar
GLR
If there is not enough draft you will get that flame. Check to make sure the chimney is clear, and the heat exchanger clear. Propane will soot up the heat exchanger and plug it or restrict air flow.
Old Nov 1, 2007 | 06:32 AM
Bruker's Avatar
Bruker
Everythings fine now. It must have been stale gas or dust in the burners because this morning the flame is as blue as can be.
Old Nov 1, 2007 | 09:00 AM
tewferford's Avatar
tewferford
It was probably dust in the air from cleaning it. I get that in my shop when I sweep the floor. The flame turns orange for a couple of mins. then it's fine.
Old Nov 1, 2007 | 09:58 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Install a carbon monoxide detector
Old Nov 1, 2007 | 10:20 AM
Bruker's Avatar
Bruker
Thanks, I already have three of them in the house.
cjben
May 3, 2010 11:31 PM
rmalottwtes30
Nov 29, 2007 11:47 PM
herman391
24
Jan 3, 2007 10:44 PM
unclehan
13
May 6, 2006 10:27 AM
couleeman
Dec 13, 2003 12:44 AM
