I am in the process of repairing some rusted body panels and attemping to learn the ancient secrets of brazing. I have the torch and bottles all set up and been burning a few items along the way. Is there any guidance or videos that you folks have used that were/was particularly helpfull. Right now I am using a #2 tip, running gas at 3lbs and Oxy at 10. I am trying to find out where the sweet spot flame resides. The test/practice metal has succombed to heat to the point of melting, at which point I realized it was too hot I would really like to do this myself, before farming it out to my kids buddy who took welding at a trade school and has toys to play with..... Any guidance is appreciated.
Just keep in mind that brazing refers to heat that will melt and not about fusion of metals like welding. Its a bonding process and the bronze rod flows at a pretty cool flame. I think you'll want a soft sounding flame rather than the more hissing one for welding temperature. Less Oxy than 10 psi is fine on the brazing process. Use plenty of flux and really move the torch with its wider flame around to spread the heat. And, you'll need a very small but ever present gap between the two pieces so the bronze can flow in and do its molecular adhesion thing.
Choose wisely what you braze or lead. Once done, it can't be welded. The molecules are saturated with the wrong stuff to weld.
Heating panels up for brazing will cause the panels to warp. Are you confusing brazing with soldering/leading, which is a lot lower heat. The color you looking for while brazing is the red color which indicates ~1600F. Are you using flux on rods or flux from a jar? In any case watch the flux, it will turn to a clear liquid color when you get close. If you having trouble seeing the color use a temp stick. As for torch, If you working thin panels you want a very quiet slightly oxyodizing (oxygen rich) torch. When you get it down you can test your skill by welding/brazing AL, it really tests your temp control.
Thanks guys. I am using flux from a can, dipping the rod in and going. I will play in the garage this evening trying to soften the flame. I am basically putting in a lower corner fender panel, about 6"x4" big. I have a nice cool wet rag to keep the surrounding area in check and have been practicing on a scrap piece of panel.
You would be better off not using brazing rod, use a reg steel rod in stead,, You will get a weld without the dis similar metals problems or making the surrounding metal brittle,,It has been my experience ,with braze, that in a short time you will see the weld through the body work....
Brazing body panels has many problems associated with it. A previous poster pointed out one of the serious ones and that is warping. Another is that brazing sheet metal together with brass will be a short term repair. The dissimilar metals will corrode and in a few years you will see the repair need to be redone.
The very best way to fuse body panels is with a MIG welder and even then you don't just take off and run a bead. You leap frog around the panel with small welds giving plenty of time to cool. You also can make a heat sink around the repair with silly putty to keep the heat contained.
If a torch is the ONLY way you have of fusing the panels, don't use brass. Use baling wire, or if in a city setting where you have no baling wire, use coat hanger wire THAT HAS HAD ALL OF THE PAINT REMOVED. Again, don't just take off and run a bead, this will guarantee warping. Spot around the panel so as to limit heat.
I'm sort of an old guy, so I have actually seen the coat-hanger method in action... I do in fact also have one of those two-voltage wire feed with flux MIGs in the garage, but I was not pleased with the outcome of it's use on the test panels. It looks like I will succomb to my lack of experience and tools and have my son's buddy just take care of it for me. What he can do in 15 minutes has already consumed a few hours of my time
Yes indeed, practice is key. It sort of reminds me of an old family joke. Our Mom told us; "Don't go near that river until you learn how to swim!" Even as kids we saw that as something impossible.
I have never tried welding body panels with flux core. It would be a real pain, since you would have to clean the weld before you could weld over it. What makes MIGing body panels practical is the fact that due to the shielding gas, you can weld over weld. Since you have to leap frog around with many small welds, you would drive yourself crazy cleaning the flux mess so that you could let welds kiss each other.
Can you get a gas setup for your wire welder? The wire welder with gas will make this a VERY easy job.
I will keep at it, but of course it will be for the experience as opposed to getting the job done. My father has a MIG with the gas attachment that we are about to convert over (from flux wire) so that way we will have both bases covered. He is an old school stick welder and the body panels are just a little thinner than he is used to working with.
