Black Soot
Old Oct 30, 2007 | 10:09 PM
jroy's Avatar
jroy
Black Soot
I just upgraded to a 4" exhaust and eliminated the catalytic converter , but now I have black soot forming on the lower right rear fender panel where the exhaust exits. The pipe is cut square. I never had this build-up before with the stock exhaust system.It was cut at an angle on exit. Is this why or am I experiencing some other problem ?
Old Oct 30, 2007 | 10:10 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
That's the beauty of a diesel. Add on a tip to get the exhaust farther away from the truck, out past the tire, or just wipe it off every now and then.
Old Oct 30, 2007 | 10:23 PM
Pocket's Avatar
Pocket
I get that soot too. It's because I tucked my exhaust pipe up very close to the panel (close enough to melt some of the plastic underneath). I had to because I go offroading, and I managed to screw up the stock tailpipe on a rock. No tip for me. I just try to keep it clean.
Old Oct 30, 2007 | 10:47 PM
Orezona's Avatar
Orezona
I don't have a tip either and I get a beautiful layer of soot. I like it. It's proof I wasn't dreaming when I saw the black in my passenger mirror!
Old Oct 31, 2007 | 12:27 AM
1996pwrstrk's Avatar
1996pwrstrk
I get soot on both sides OOOHHH YAAAHHH !!
Old Oct 31, 2007 | 01:16 AM
foxracer800's Avatar
foxracer800
Time to get that sticker that says "It's not pollution, it's horsepower!!" to let the non-power strokers know that everything is OK!
Old Oct 31, 2007 | 09:28 AM
jroy's Avatar
jroy
Black Soot
All righty then......thanks for everyones input . I thought something was up with my motor ! I'll just keep on towing and going ! Thanks again, this place is great.
Old Nov 1, 2007 | 08:50 PM
kilapapipa's Avatar
kilapapipa
I get some on my tire, LOL scratch that, I get a lot but I like it.
http://i26.photobucket.com/albums/c1...D/0b75a22d.jpg
Old Nov 1, 2007 | 10:56 PM
CanadianSmokie's Avatar
CanadianSmokie
I am assuming the cat on the PSD is the same as on a mercedes. If it is, it's not a true catalytic converter but a partical or soot trap. Removing it would definitely explain your increased soot level leaving the tailpipe.
Old Nov 1, 2007 | 11:17 PM
jtharvey's Avatar
jtharvey
No particluate or soot trap on these trucks...not until the '08 6.4. The 6.4 is the first of the Super Duty trucks have a particulate trap.
Old Nov 2, 2007 | 12:31 AM
jhand124's Avatar
jhand124
I'm probaly totaly wrong, but does CA have/had diff emission specs on diesels, could a CA truck have a particluate or soot trap?
Old Nov 2, 2007 | 03:01 AM
ernesteugene's Avatar
ernesteugene
The CAT on a PSD is most certainly a soot trap! I bought my truck new in 1/99, drove empty for about 5 K miles, and then went fulltime and towed from Wash DC to RGV in TX, and removed my CAT to install a Banks exhaust and a US Gear exhaust brake. I could not see any light coming through the CAT with my powerful flashlight in one end. I banged the CAT on the floor and a big pile of soot came out. Banged it again an another pile came out. They guy said stop doing that your getting soot in the air and I can't breathe. I threw the CAT in the trash, so I never did find out just how much soot was in there.
Before I left the garage I'd gotten a Banks Stinger system installed, gauges, etc.., so it's hard to say how much improvement getting rid of the CAT made, but it was so full of soot it had to be hindering performance considerably.
Old Nov 2, 2007 | 10:46 AM
jtharvey's Avatar
jtharvey
Well Gene, you do have a point...the cat probably does trap some soot. However, I was referring to a specific piece in the exhaust designed exclusively to trap the particulate matter. Those didn't show up until '08. I don't think the cat was designed to remove the soot, but as a result of being in a sooty exhaust stream, the cat will catch some particulate matter on it's tiny internal passages. The new '08 trucks have both a cat and a particulate trap.
Old Nov 4, 2007 | 08:41 AM
kilapapipa's Avatar
kilapapipa
Also, there were a couple of years when Ford did not put a cat on the 7.3 and my 2000 is one of them. I think late 99-01 did not have a cat if I remember correctly.
Whitson Metalworks
30
Oct 26, 2015 08:27 AM
Jason Lewis
98
Jul 4, 2011 08:35 PM
BRay09
18
Aug 6, 2010 03:48 PM
acm05fsu
Exhaust Systems
Aug 4, 2007 05:42 PM
