White smoke and black soot on exhaust... Heads or rings?
Try pressure testing of the cooling system with one of those cooant pressure testers that fit into the cap opening of the radiator and see if the cooling system maintains pressure.
if the oil cooler was leaking there would coolent in the oil and it would be a milkey tan color in both the oil pan & radiator and it would be pushing the milkey goop out on the cooler over flow.
see as your using more oil and getting more smoke at higher RPM's
I would say rings.
Do you get alot of blow by out of the dip stick tube & oil fill cap?
I had a Dodge years ago that did that, the oil rings were so bad it spit oil out the exhaust pipe's
I would say rings.
I would say rings.
I would say rings.
what I ment by Blow Bye was combustion pressure & smoke from the motor
threw and type of vent dip stick tube or open fill cap.
if you dont have excessive blow bye I wouldent think its rings or a piston
I would do a compression test and try to find out which cylinder is cousing the problem also take a look at you spark plugs see if any are black and carbon coverd thats a good indicator of burning oil
its posable that this is a head problem (valve guide & seal)
on
You can also put in a chunk of clear radiator hose and watch for bubbles passing by. That's what we do on our semi.
