first engine build
Old Oct 30, 2007 | 09:18 PM
justboughta77's Avatar
justboughta77
Lightbulb first engine build
Hello everyone, I have a 1977 F-100 short bed 2wd with a 302. I am looking for some other ideas for the motor that won't cost me an arm and a leg.
Here is what I have done so far:
* Hedman Headers
* aluminum performance air gap intake
* Holley 650 double pumper carb
* polished aluminum valve covers
* NGK plugs
* Accel 8mm wires
* new thermostat
* new fuel filter
* added a radiator overflow
* all new felpro gaskets
* 14" open air breather
* MSD super coil
* MSD distributor cap
* electric fan setup
* dual Delta Flow 40 series mufflers with turn down pipes.
I also plan to add an oversized radiator from a big block to help with cooling issues.
I have run out of ideas......need help
Thanks
Old Oct 30, 2007 | 09:20 PM
justboughta77
sorry accidently repeat posted
Old Oct 31, 2007 | 08:51 AM
Conanski's Avatar
Conanski
Find a set of late model heads (E7TE casting), and upgrade the cam to something respectable.
Old Oct 31, 2007 | 09:19 AM
s1120's Avatar
s1120
As said, diferent heads are a good start, and DEFENTLY a cam change. The rest of the mods will do noting with that lame smog era cam in there.
Old Oct 31, 2007 | 09:59 AM
Kemicalburns's Avatar
Kemicalburns
run autolite or motorcraft plugs not ngk's.
Old Nov 1, 2007 | 07:53 AM
GlennFordx4's Avatar
GlennFordx4
I think that carb is going to be a little over kill a 600 with vac secondarys would be my choice.And as much as I like NGK plugs I would run motorcraft or autolights also.
Old Nov 1, 2007 | 06:21 PM
baddad457's Avatar
baddad457
650 DP is definately too much carb for a stock to mild 302. It'll run quicker with a vac secondary 600 Holley with a lighter sec spring than the 600's come with. I use the lightest to next to lightest spring for this. Another good choice is a 570 Street Avenger.
Old Nov 3, 2007 | 11:37 AM
Mr. M's Avatar
Mr. M
If you run an MSD system, your pickup will benefit from the NGK's gap capability (0.060" +)
Stock coil, dizzy and no MSD 6a box.... run motorcraft like Kem said.
A cam upgrade and some pocket ported e7 heads would be a great benefit for the little smallblock.
That carb is overkill, as has been stated earlier.
Good luck,
Mike
1951flatheaddave
22
Oct 18, 2017 09:41 AM
abelmoreno
Mar 27, 2016 07:27 AM
ABeautifulTree
26
Sep 22, 2015 02:02 PM
HangGlider
Jun 7, 2007 07:49 AM
