So it appears that the transfer case on my shift on the fly is not dissengaging. I appears that the hubs are. However the other day they started clicking like my old truck did from time to time. . . as if they were trying to engage while moving. So starting with that we have problem number 1. here are the codes for the 4wheel that i pulled. . .
P1670 electronic feedback signal not detected- P1812 4-Wheel drive mode select circuit failure- P1867 transfer case contact plate general ciruit failure
I'm not sure what the 1670 is or means. . . any clues? So I new that this system would eventually give me trouble. . . so for those who already have had to deal with it. . . what do you think? Thanks.
Tim
hey go to my post i got up 4x4 wont disengage sounds like u may be haveing the same problems as me...or close to the same anyways.let me know im trying to troubleshoot it right now,from 8000 miles away lol.
also if u dont mind me asking how did u pull those codes?or rather how would i pull codes on mine,or explain to someone to pull the codes?
P1670 electronic feedback signal not detected(quote) when a commanded injection driver module(IDM)response is not received this fault is set! thats all i can tell u!
hmm thats interesting, I think that might be a new one. .. . just temporary while I have my HPOP out and a lot of sensors disconnected
Tim
