I took out the engine ,
I found: holes in the oil pan (both sides)
small portion of the block (where the engine support is attached to the engine)
and the coolant running out trough one of the holes.
My question is if this engine can be rebuilt , I dont know if the small part of the block can be welded .
According the coolant leak , I presume the cylinder wall is broken.
I need your opinion : rebuilt or change?
anyway if somebody has a good engine or block just let me know
thanks a lot!
thanks a lot!
You now have a good boat anchor. That thing is useless for anything else at this point.
thanks a lot!
For our info., would you give us some background on the motor please? You know, mods, miles, what your doing when she went boom...
I have said this for years that PMRS are inconsistent and can not be trusted. I tell every customer I have this when they buy injs for a PMR motor. There has been some that can run Stage 3 injs and get away withi t with PMRs but they are playing with fire for sure, this would not be the first one to throw a rod with no mods.
I would help you out but I have no good cores at the moment to build for you.
