On cooler mornings (+-60) my truck starts up just fine, runs only slightly rough for 2-3 seconds then smooths out. After a few minutes it will start to rev out a little and then bog like it is starving for fuel, I pump the throttle a little and after a moment smooths out. This doesn't seem to happen until I actually put the truck in gear and start driving. Then it happens sometimes in 2nd or 3rd gear. Runs great the rest of the day after the motor has warmed properly. Has a fresh fuel filter and the injectors are maybe 3 years old. Ideas? Thanks.
Do a pressure and flow test of the fuel pump at the Schrader valve on the filter header (FSS- fuel shutoff solenoid disconnected on IP). Remove the tire valve core and hook a hose and pressure guage on it should see 4-6 psi when cranking. Then do a fuel quantity test same place, should see 1/3 pint in 10 seconds of engine cranking, route fuel to a suitable container with a hose.
If there is a problem with the lift pump and you are changing it, ensure the new pump comes with instructions as to correct installation procedure if it is the newer model pump with the almost straight arm.
Where is that lift pump located and can it be the source of the air?
Other question, my Injection Pump is leaking fuel, maybe on start up, not sure. Puddling on top of the intake manifold. Time for a new one? The truck will hesitate (surge) at high rpm when I am really on the throttle for hard acceleration. Has done that for a long time, so I just don't go there. Though it is fun to lay the black cloud on the joggers!
usually if the ip is leaking it will leak at the weep hole ... located at the bottom of the neck behind the mounting flange. make a wipe from paper towel and run it beneath the flange. you may also be getting air intrusion from the return tees or leaking from the weep hole in the lift pump (same location as older type gas fuel pump on the side of the engine).
not going to say it is the ip til further checking is done and all else is eliminated. start cheap.
been searching all over the forums for this info... not finding it.
I want to disable my glow plugs so they are not draining my battery while I do a compression test... guess ill just start pulling wires till the controller dont click.
