Need...More...Brake
Having driven many other vehicles, one is a 2005 2500HD chevy with 105K towing miles on it, with original brakes and it has very good brakes.
I replaced the pads all the way around mine about 10K ago, because I thought that was causing my problem. I have to put the pedal really far down to get any amount of brake force.
I thought maybe it was just how these trucks were, but I test drove a Diesel SD the other day and the pedal on it only moved about an inch and I had full on brakes, much harder than my truck has EVER stopped.
What am I missing here?
2002 F-250, 4x4
67,500K
Is this a new problem, or was it better before? If the pedal is really going down a ways, may need to look into other things. Is it going down under moderate pressure, or when you really stand on it just to get the thing stopped? Try and give a little more detail and I'll try and offer more/better suggestions.
Chris
But if I was to compare it to the Diesel I drove I would have to say it is VERY spongy. The diesel had awesome brakes.
It is like I have to push the pedal down about 2-3" before I really get any major stopping power at all.
Agree with others that if your calipers/system is mechanically sound then you should try fully bleeding your brake system to purge all old brake fluid.
Also, what brake pads did you use and what is their friction coefficient and over what operating temperature? Brake pad material differs quite a bit in how much grip it has, and to some extent the temperature of the pad.
If you lookup, say, a Ferodo DS3000 you should note the high .62 coefficient over a smooth temp range. Look at other pad material and see how things change. All brake pad material is not created equal.
FYI: In one street/track car i had to use DS1000 front and DS3000 rear as i wanted to avoid using a MC brake balance system after upgrading only the front calipers/rotors.
Will avoid the solid vs slotted vs drilled rotors discussion as am sure your truck uses solid rotors.
Ok, i'll bite. Drilled rotors for the street are for poseurs in general Ok, so there are exception being to truly reduce rotating mass for racing BUT then you lose brake pad grip area so suffer reduced braking ability. Also, drilled have a nasty way of playing 'conect the dots' and trust me, you don't want to know what happens to cars when the drilled rotors shatter and lock up one side of the rear wheels at the track and/or take out or bend a brake caliper in the process). Suffice to say it is U-G-L-Y.
Slotted, good way to go to keep pads clean. The 'myth' of pads needing outgassing is basically BS though slots do seem to keep thing clean and help water evacuate a bit for guys who drive/race their cars in the heavy rain (read: not NASCAR).
Solid: Good way to go, complete area for pads to grab. It is rare that solid rotors show signs of cracking, but i have seen it on those cheap $35 aftermarket Corvette rotors the track guys buy at ??? But hey, for $35 they are total throw away items every weekend at that cheap price.
Note that i am talking about metal rotors, no cheating and bringing up CF or other exotic materials/mixtures (you got that MrCMK bub LOL). If you have to ask what a complete CF brake system costs due to financial/budget concerns, you probably don't want to consider CF. The last guy i knew that changed CF rotors before a track event was $22k lighter in his bank account.
I'm a huge fan of the brembo blanks. You can get them from tirerack and they are usually the same price as the ones you get from the auto parts store.
The Cobra brake kit I put on my 'Stang came with the cobra twin-pot calipers, pads, brembo blanks and stainless lines. The thing stops on a dime and will give change.
So, about those CF systems...
And I repped you for the good info
2002 F-250, 4x4
67,500K
Most shops don't completly flush the fluid in the brake system and add new. (Just top the resivoir off) Like misterCMK said brake fluid attracts water just like alcohol.
My dad put Slotted Cryos and Hawk SD pads on the front of his 03' and they stop better than the stockers once they warm up.
