Edge....Bad
Old Oct 28, 2007 | 06:40 PM
Knotwild's Avatar
Knotwild
Edge....Bad
I just bought an F250 4x4, .355 gearing and a five speed, about 3000 miles ago (150,000) total. It came with an Edge tuner and everything else stock. I did add a 3" downpipe. The guy I bought the truck from had been running the Edge in the first setting (tow, about 60 hp). The truck gets about 19 mpg in that setting; however, it makes an annoying vibration if I accellerate without downshifting. I.e. I slow down to 40 and simply push the pedal to the floor to speed back up to 55, it vibrates bad enough to make me downshift or ease the fuel to it slowly from 1100 rpms until about 2200. Once it hits 2200 or so, it smooths out and really takes off.
Does anyone have any idea what the vibration is? It is not u joints as I checked them.
It annoyed me so much I used the Edge to go back to the stock setting. The truck is quieter and much smoother, although I feel the power difference. The vibration is still there, but it is so faint I can live with it.
My next step is to move up to a Wildman or DP chip!
Old Oct 28, 2007 | 06:44 PM
FFemt5287's Avatar
FFemt5287
might it be the new downpipe hitting the firewall?? just a thought...
-Brandon
Old Oct 28, 2007 | 06:50 PM
powerstroked162's Avatar
powerstroked162
Is it a knock sound? Im leaning towards the dp hittin the firewall as well.
Cowboy Steve
Old Oct 28, 2007 | 06:55 PM
jboard's Avatar
jboard
Check your turbo wheel and the turbo shaft play...mine was acting just as yours was...mine had a chipped turbo wheel and some shaft play which would cause a type of studder from the engine it wasnt a harsh u-joint vibration it was a softer engine spudder before the auto would shift down. I have a hypertech tuner I believe it had something to do the the turbo not working up to par therefor it couldnt burn the extra fuel the chip gave it. I put a new SD turbo wheel on it and rebuilt the turbo and put a 1.0 exhaust housing on it. Havent had the problem since.
--------------------Jeremy
Old Oct 28, 2007 | 07:06 PM
strokin'_tatsch's Avatar
strokin'_tatsch
i'm thinking it's either the downpipe hitting the firewall OR could it be a dual mass flywheel acting up????
Old Oct 28, 2007 | 08:06 PM
Knotwild's Avatar
Knotwild
Thanks
Thanks for the input guys. I should say that the vibration I described can be felt and seen on the gearshift. You can see it move. Part of it may be that I am expecting the diesel to make enough torque to smoothly bring me up to speed, when I need to downshift anyway.
Although the downpipe does have an awfully close fit, it is not the problem.
If it was the turbo chipped or damaged in some way, why would it smooth out and make power after 2200? And why wouldn't it be just as bad with the stock tuning.
I have to admit it is baffling me.
Old Oct 28, 2007 | 08:07 PM
Knotwild's Avatar
Knotwild
Jeremy:
I just read your post more closely and it sounds like I really need to check my turbo. Your description of the vibration is close to mine.
Old Oct 29, 2007 | 06:04 AM
jboard's Avatar
jboard
Yea Its a very odd problem but inspect the comp wheel for any damage. These things spin over 100,000 rpm so the slightest imbalance only gets worse overtime.
------------Jeremy
Old Oct 29, 2007 | 05:43 PM
WALJON's Avatar
WALJON
SURE sounds like the flywheel I would check there first
Old Oct 29, 2007 | 06:00 PM
97 HD's Avatar
97 HD
mine will shake to if i lug it. i think its the Dual Mass Flywheel.
995.4SD
Apr 23, 2014 07:20 PM
Rus01
6.4L Power Stroke Diesel
Jul 13, 2013 08:44 AM
Atc210
Dec 1, 2012 03:50 PM
theduke308
2004 - 2008 F150
Feb 21, 2012 05:18 AM
mjs
Jun 21, 2005 09:46 AM
