Install Question -- MSD 6a Ignition
Old Oct 30, 2002 | 11:34 PM
str8six's Avatar
str8six
I have heard that an MSD 6a ignition box seems to be an ideal way to help wake up the inline 6 a bit for some power. Is this an easy thing to install? If not, would anyone care to give any pointers or advice to make the install go smoother? Is there anything else like wiring harness, plug wires, etc, that I would need to also buy to run this ignition box? Thanks!!!
Old Oct 30, 2002 | 11:35 PM
tetraruby's Avatar
tetraruby
On what year truck?
Old Oct 30, 2002 | 11:48 PM
str8six's Avatar
str8six
Sorry 'bout that. Its an 87 XLT Bronco
Old Oct 31, 2002 | 02:55 PM
tetraruby's Avatar
tetraruby
I'm not sure on an '87. I did the upgrade on my '79. Damn computer and all...
Old Oct 31, 2002 | 03:02 PM
whittey's Avatar
whittey
Simple.... Get the box and get the TFI-IV adapter, then splice into the wires that it tells you to and you're done. A 1 hour project.
-=Whittey=-
Old Oct 31, 2002 | 03:05 PM
tetraruby's Avatar
tetraruby
Go to http://www.msdignition.com/ down load the instructions for the 6 series. On page 19 there's a couple of diagrams for the TFI setup. I think fordsix has the same exact diagrams in their tech section. It wasn't that difficult on my truck, my complaint is that the leads are a little short. I had to lengthen all of them to do a clean install. I noticed a difference over the stock setup, but it wasn't some shocking experience. I do notice my truck starts up a lot easier and rev's smoother. After five months I have had no problems - normal plug, cap, and rotor wear. Buy the harness, it makes the conversion easier - especially if you think you'll ever take it out.
Old Nov 7, 2002 | 09:02 PM
str8six's Avatar
str8six
Thanks Whittey. What is a TFI-IV adapter? Also, you mentioned theres splicing involved. Can the splicing be avoided by also buying a wiring harness? I thought I heard theres a wiring harness available to avoid any splicing. TIA
Old Nov 8, 2002 | 07:17 AM
whittey's Avatar
whittey
Well, the only one i've done recently was a mix between TFI-IV, DII and Crane, all without any engine harnesses. So everythign there was splicing. With a straightup TFI-IV for the sake of ease, get the TFI-IV adapter kit and follow the instructions. I can't see it being very hard at all.
-=Whittey=-
Old Nov 8, 2002 | 10:19 PM
Silver Streak's Avatar
Silver Streak
95F150Guy
72
May 5, 2011 09:39 AM
taxabel
Mar 13, 2005 09:35 PM
djmac
Electrical Systems/Wiring
May 8, 2004 12:26 PM
GammaDriver
Aftermarket Products
Apr 21, 2002 09:04 PM
Njbmx
Apr 12, 2002 11:01 PM
