Help-Plugs for MSD 6AL
Mar 12, 2005 | 11:39 PM
I have a 1993 f150/5.8 4x4, I'm installing the MSD ignition components with new wires, etc.. What is the best plug to finish the install?
Mar 12, 2005 | 11:42 PM
Boush? platinum never let me down!
Mar 13, 2005 | 05:15 AM
Motorcraft plugs have always worked for me. The Bosch with a single electrode may indeed work well, just never tried them.
Mar 13, 2005 | 08:39 AM
With my 6A, I run regular old NGK v-power resistor plugs. Nothing fancy; stock type plugs are fine, and no platinum for me.
Mar 13, 2005 | 11:15 AM
Do you notice an improvement in perrformance with your MSD 6?
Been looking that over along with a Blaster 2 Coil myself.
Tim
Mar 13, 2005 | 11:34 AM
just stay away from the gimmicky plugs, you know the ones, multiple legs around electrode.
autolites seem to work the best for me
Mar 13, 2005 | 12:04 PM
Mar 13, 2005 | 12:46 PM
NGK Spark Plugs
NGK may very well be a good plug as well as Bosch. I think I'll continue to use good old Motorcraft and let the Japanese and German economies benefit in other ways. I might try Autolite, Ford after all. I've just never had a complaint with the Motorcraft.
Mar 13, 2005 | 08:52 PM
Only thing I noticed with the 6A was a little bit smoother idle. Performance was about the same, but I already had the blaster TFI coil.
Mar 13, 2005 | 09:35 PM
Ya, I'd say use the NGK v-groove. I got a blaster coil, cap, rotor, wires and NGK plugs and there was a definite increase in power
bjoern
May 7, 2022 02:58 PM
WyoExplorer
24
Mar 17, 2010 09:42 PM
mike460
Mar 12, 2003 11:55 AM
Njbmx
Electrical Systems/Wiring
Apr 12, 2002 11:01 PM
lipton
May 1, 2000 06:27 AM
