Horsepower theft
Old Oct 28, 2007 | 12:04 PM
ozone11's Avatar
ozone11
Horsepower theft
what other stock parts rob a vehicle of power? I have already replaced the oil/filter, air filter, spark plugs, and PCV valve. Thanks for the help.
1993 Ford Ranger 4x4 4.0
ozone11@cinci.rr.com
Old Oct 28, 2007 | 05:08 PM
pawpaw's Avatar
pawpaw
Fuel filter, spark plugs & wires, worn distributor cap & rotor, dirty MAF sensor & throttle body, dirty fuel injectors or EGR valve, lazy O2 senors, plugged cat converter, or bent closed/restricted exhaust system, big tires, low tire air pressure, wrong viscosity lubricants, poor quality fuel, or wrong octane fuel, lugging around unnecessary weight are a few things that come to mind.
I see you have already replaced some good suspects.
Maybe just bring this puppy up to date on due, past & present scheduled maintenance items.
Your owners manual, or scheduled maintenance book would likely list them all.
Old Oct 28, 2007 | 08:09 PM
ozone11's Avatar
ozone11
thanks for the info
Old Oct 29, 2007 | 12:10 AM
Bear River's Avatar
Bear River
Former ******
Yeah, doesn't narrow it down much. For the record, the plugged cat is usually caused by other problems that rob power, such as leaking injectors, faulty O2 sensors, or fouled plugs. So don't jump to the conclusion of a clogged cat unless the other factors have been investigated.
Old Oct 29, 2007 | 01:43 AM
mfp4073's Avatar
mfp4073
I have found in my performance applications that plug wires, cap, rotor and plugs cause more problems than most people realize.
91dirtydiesel
Dec 6, 2010 04:02 PM
ozone11
Oct 28, 2007 08:59 PM
fabmandelux
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Apr 9, 2006 01:38 AM
fordguy101
34
Oct 12, 2005 06:35 AM
grogant
Ohio Chapter
Apr 1, 2004 07:20 PM
