EGR Valve
Old Nov 10, 2002 | 01:39 PM
homedepothauler's Avatar
homedepothauler
EGR Valve
[updated:LAST EDITED ON 10-Nov-02 AT 03:32 PM (EST)]I am recieving a code 32 on my scanner. I took in the EGR Sensor and had it tested it was "fine". I pulled off the EGR valve and it is nice and clean. The spring works great etc.
Any Suggestions?
1989 Ford F150 300 EFI Inline V6 2WD 82,000
Old Nov 10, 2002 | 06:27 PM
Chipster's Avatar
Chipster
EGR Valve
Have you checked to see if the EGR valve sensor is receiving +5 vDC? One pin is ground, one pin is supply voltage, and one pin is the EGR signal. Check the EGR wiring harness with the key on and the engine off.
Old Nov 10, 2002 | 07:22 PM
homedepothauler
EGR Valve
[updated:LAST EDITED ON 10-Nov-02 AT 08:23 PM (EST)]FYI
Being of little patience, (wife on my ***) I went ahead and replaced the EGR Sensor. Since I installed it I no longer receive the error. I guess Autozone can only test so much.
Now its time to watch the baby!
Old Nov 10, 2002 | 10:24 PM
heathdaily's Avatar
heathdaily
EGR Valve
Midnite1987
26
Jan 3, 2012 01:27 PM
loneleader
Jan 25, 2005 06:55 PM
lm1d
1997 - 2003 F150
Dec 8, 2004 08:14 AM
JCastellaw
Jan 16, 2004 11:35 AM
jams3
19
Aug 5, 2002 09:12 AM
