Dana rear end
Old Oct 27, 2007 | 11:21 AM
Texas Monty's Avatar
Texas Monty
Dana rear end
I have a 64 - and the rear end is a Dana 60. While changing out the front seal, the pinion yoke broke - and this is one of those parts that I cannot find at any of the usual suspects (Macs, LMC, NPD, etc). This is the connection to the u-joint on the drive shaft.
Is this part impossible to find? any clues or ideas - other than crawling around wrecking yards - what there is left of them with old fords.
Old Oct 27, 2007 | 12:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
AXLE code B5 (Right?) Dana 60.2 / 4.10-1 / Limited Slip / 3300 lb. Rear Axle Capacity / Parts List # 168
B5D-4851-A .. Companion Flange
FTE sponsor Green Sales has 5 new originals in stock.
800-543-4959 M-F EST
Old Oct 27, 2007 | 04:43 PM
Texas Monty
Pinion yoke
Yep - that's it . I can't seem to find that part on that web - without the Ford number, but I will call them Monday.
I want the ring and pinion set as well.
What ratio would you go with? 3.25 or 3.51? I have the 4 speed with Granny. Pretty tired of this 4.10.
Old Oct 27, 2007 | 06:50 PM
NumberDummy
Your type of Spicer-Dana 60 only came with two ratios: 3.54-1 or 4.10-1.
p0opstlnksal0t
Sep 12, 2014 02:50 PM
jtindale
19
Mar 8, 2013 01:29 PM
Tomahawk2506
Jun 16, 2012 04:46 PM
rblomquist
Jul 16, 2005 11:20 AM
rebocardo
Nov 23, 2002 09:08 PM
