trying to find this code
Old Oct 26, 2007 | 05:37 PM
dean1276's Avatar
dean1276
95 f 250, check engine came on yesterday and could only drive 35 so upon scaning it it gave a code of 276 low side short to ground (g) cyl 6 the question is where is cyl 6 and what do we fix.... thanks
Old Oct 26, 2007 | 05:45 PM
c00nhunterjoe's Avatar
c00nhunterjoe
sounds like the under valve cover harness melted, common problem, remove the valve cover and look for smoke
Old Oct 26, 2007 | 06:14 PM
tjbeggs's Avatar
tjbeggs
I would be testing that wiring with an ohm meter before you pull the VC. To test you need to get a digital ohm meter. As always I can't remember cylinder location! (anybody??) Any way each valve cover has 2 connector each with 5 pins
they will look like this
1 2 3 4 5
_ _ _ _ _
1 and 5 are glow plugs. 3 is common for two injectors and 2 and 4 is the low side for 1 of the two injectors. So i think number 6 is the passenger side second from the back. so if thats the case you will need to connect your ohm meter to pin 3 and 4. if you have more than 3.5 ohms you have wiring issues under the valve cover. if you have 3.5 or less your good under there and need to look at the main engine harness for chaffed wires.
Old Oct 26, 2007 | 07:17 PM
1997F-350's Avatar
1997F-350
6= drivers side IIRC.
plug right under intake of turbo.
Old Oct 26, 2007 | 07:29 PM
tubzz's Avatar
tubzz
IIRC
odds passager side
1,3,5,7
even driverside
2,4,6,8,
or was the other way
Old Oct 26, 2007 | 07:54 PM
tjbeggs's Avatar
tjbeggs
Ok well 2 say driverside i thought passenger. majority rules! And I think they are right anyway!! Drivers side second from the back. The hard one to check!! turbo intake has to come off.
Old Oct 26, 2007 | 08:55 PM
c00nhunterjoe
my guess is the one that doesnt ohm out
Old Oct 26, 2007 | 08:58 PM
tjbeggs's Avatar
tjbeggs
If it doesn't it doesn't but it sure would be a shame to pull the VC and replace parts and not fix the problem
Old Oct 26, 2007 | 09:04 PM
c00nhunterjoe
sorry, i'm eating spongebob icecream again
Old Oct 26, 2007 | 09:21 PM
tjbeggs's Avatar
tjbeggs
I ate all mine last night!! BOOOO.... no ice cream for Tim!!
Old Oct 26, 2007 | 09:33 PM
c00nhunterjoe
you can come on over and share mine. it might be melted by the time you get here but the fridge is full of beer
Old Oct 26, 2007 | 10:05 PM
tjbeggs's Avatar
tjbeggs
Yeah your only about 13 hours away!! I went to college up in Scranton so I would have been about 3 hours away then.
