HELP! Everything gone wrong at once.
Old Oct 26, 2007 | 05:54 AM
seangoodwin's Avatar
seangoodwin
I'm totally stumped. I went out of town on Tuesday and my truck was running fine. Came back on Thursday night, got in my truck and here's what happened (all at the same time):
1. ABS light came on.
2. Speedometer won't work under 35MPH
3. Truck won't shift up until 3500 RPMs and then feels like it shifts from 1st to 3rd.
4. When it downshifts, it does it with a "clunk"
5. When I came up the last hill to my house it felt like the transmission was slipping. I'd let off the gas, it would downshift and then it was ok until I went faster and then it would happen again.
6. "O/D Off" light starts flashing above 35MPH but quits when I go below that.
I checked all the fluids and everything is fine. I disconnected the neg battery for 30 minutes in case it was a computer hiccup. That didn't help.
Before I have it towed to the mechanic, does anybody have any ideas?
TRUCK DETAILS: 2000 Ranger TrailHead; 3.0; 136k miles; automatic; 2WD
Old Oct 26, 2007 | 06:30 AM
03 Maz B23's Avatar
03 Maz B23
Sounds like it could be the speed sensor that is in the differential. It is an inexpensive part that has been known to fail.
Old Oct 26, 2007 | 08:21 AM
Pablo-UA's Avatar
Pablo-UA
VSS ore VSS wiering. I'm not sure about location, I saw VSS in rear diff., in tranny of my old aero, ore as VSS ABS sensors may be used (on some bosch abs). Pull OBD-II codes. Check VSS signal with o-scope. May be signal is low.
Old Oct 26, 2007 | 08:27 AM
seangoodwin
Thanks. Just picked up a sensor from the stealership so I'll give it a try and let you know. Thanks for the help!
Old Oct 26, 2007 | 04:21 PM
seangoodwin
It was definitely the speed sensor ($28 at the stealership). It was easy to get to after I dropped the spare tire. The sensor is right on top of the "pumpkin" (as my dad calls it). Sprayed the bolt with WD40 and left it for 20 minutes. The bolt came right off. Couldn't have been easier. Thanks for the help!
Old Oct 27, 2007 | 11:03 PM
Bear River's Avatar
Bear River
Former ******
I agree with all these suggestions, a bad speed sensor will cause all of the problems you listed.
Old Oct 28, 2007 | 09:22 PM
mfp4073's Avatar
mfp4073
good god! thats bad! I got one from napa last week for $11. Discount auto and autozone wanted $22ish.
Old Oct 28, 2007 | 10:19 PM
ValkyrieVixen's Avatar
ValkyrieVixen
Oooh, good to know mfp, I was gonna get one from the dealer.
I get a discount from NAPA too since I work at a restoration shop. Yay
Old Oct 29, 2007 | 01:41 AM
mfp4073's Avatar
mfp4073
I have to admit, I got the idea from someone that posted on this board while I was reading the back logs. Its an easy fix too. Solved 2 of my problems related to shifting and ABS error codes, took 15 min to do.
