Coolant flow direction?
Old Oct 25, 2007 | 10:11 PM
99BlueOval's Avatar
99BlueOval
I have a 1988 300 I6 F150. I have swapped in a 94' I6 from a E150. My problem is I cant remember if I bought a water pump for the 88' motor or the 94'. I busted a crack on the tank off the radiator & I don't know if it was because it was old to much pressure. My T-stat is opening & I am replacing the Rad this weekend. I just want to know if I need to replace the water pump again.
I noticed recently noticed on a few parts sites that they are separate part numbers. Any help would be appreciated.
Old Oct 26, 2007 | 03:15 PM
mhg's Avatar
mhg
not really certian of what your ? is
your pump should be what your drive system is
if your 88 has V belt then order one for that year
if you used the later model serpintine sys then
you need one to match that type which
uses a reverse flow pump because the belt turns the water pump
backwards as compared to a V belt sys.
Old Oct 27, 2007 | 07:54 AM
99BlueOval's Avatar
99BlueOval
My 88' & the 94' both were serp, but autozone has different part# listed.
Same moter should be same parts
Old Oct 27, 2007 | 08:24 AM
mhg's Avatar
mhg
have them pull both pumps and compare if there are
any major differances
if not then I would go with the later model
just incase there were updates to the pump that are not visable
Old Oct 27, 2007 | 08:41 AM
99BlueOval's Avatar
99BlueOval
Good point
thnx
exbxtoy
Jan 28, 2016 02:37 PM
bluemtn95ford
Oct 4, 2015 09:25 PM
SoCalAngler
48
Aug 22, 2014 01:57 AM
hugger94
1997 - 2003 F150
Feb 21, 2005 11:19 PM
