Sponsored by: Auxito
Need help finding out whats wrong
Old Oct 25, 2007 | 07:14 PM
DaBossF250's Avatar
DaBossF250
I need help finding out whats wrong with my 1999 F150 it is making a high pitch noise in the rear of the truck only when I accelerate. The truck is 2WD and has 186,000 miles and a new transmission in 2004 and the truck is in very good condition. Does anyone know what I can check, or know what may be the problem?
Old Oct 25, 2007 | 08:07 PM
fordtech6600's Avatar
fordtech6600
Do you hear it going down the road while your cruising along or does it happen only when you get on it? I mean it could be a u-joint or pinion bearing or something else in rear end!
Old Oct 25, 2007 | 08:21 PM
Bobby82490's Avatar
Bobby82490
Maybe a u-joint? Unhook the driveshaft at the differential, and move the u-joints around. They will be hard to turn or have slop in them.
Old Oct 25, 2007 | 08:47 PM
DaBossF250's Avatar
DaBossF250
it happens when only when I accelrate from 1 to like 70 MPH but when I let off the gas pedal the sound goes away, but I do know it is coming from the rear of the truck
Old Oct 25, 2007 | 08:54 PM
fordtech6600
You can block the front wheels and put the rear wheels up on jack stands and then run the vehicle until you hear the noise. Then get someone else to run the vehicle until you hear noise and while you find out where it is coming from.
Old Oct 25, 2007 | 08:59 PM
Ultramagdan's Avatar
Ultramagdan
Be careful when you do that. Make sure the vehicle is firmly supported and don't speed the tires up to a high speed. It may not make the noise because there is no load on the drivetrain when the wheels are off the ground.
Old Oct 25, 2007 | 09:00 PM
Half Breed's Avatar
Half Breed
This would be what I would try. Be sure and have it blocked up very well. Safety first.
Old Oct 25, 2007 | 09:12 PM
DaBossF250's Avatar
DaBossF250
I am going to try this, and then try to find the noise, thanks for all the help
gfe
6.4L Power Stroke Diesel
Aug 18, 2011 02:50 PM
SUPERDUTY OUTLAW
Mar 7, 2009 07:48 PM
whybnormal
Oct 14, 2007 10:09 PM
powerslave
General Automotive Discussion
Nov 27, 2004 10:29 AM
StanJD54
Mar 24, 2003 05:14 PM
