Modular V10 (6.8l)
Broken Manifold Studs Argh!!!!! Help
Old Oct 24, 2007 | 10:24 PM
bookum1's Avatar
bookum1
I thought all was fine with my 01 F250 V10. I bought it used with 110K miles. Truck seems to run well, but read a lot about broken exhaust studs and checked mine. Guess what, textbook two rear passenger side bolts broke. One of the studs is broken flush with the head and one flush with the manifold. I don't want to cause a problem where there isn't one, but I think I can probably fix it without removing the manifold. I shoould be able to use an easy out or just drill them out using the manifold as a guide hole.
Any help would be appreciated.
Old Oct 24, 2007 | 10:55 PM
01 superduty's Avatar
01 superduty
I have a 01 v-10 just changed the exhaust studs, You will be better off to change them all, you will be glad you did
Old Oct 24, 2007 | 11:01 PM
bookum1's Avatar
bookum1
did you have to remove the manifold?
Old Oct 25, 2007 | 11:28 AM
nwo's Avatar
nwo
If two are broken, your best bet is to change them all. Maybe put headers on while you are at it- Be carefull those are alluminum heads.
Old Oct 25, 2007 | 01:02 PM
dkf's Avatar
dkf
I just got Thorley headers installed on my 04' w/ 27k before any studs were broke. When the shop put the headers on they found one of the studs was indeed busted off below the manifold flange.
I would definatly change all the studs because they will break. Its sort of a pay me now or pay me later type deal.
IMO a well maint. 04' like mine w/ 27k should not have any broken studs, but what do you do.
Old Oct 25, 2007 | 03:49 PM
hydro_37's Avatar
hydro_37
Ford originally used steel studsfrom what I have read here. Make sure you get stainless one to replace them. The Ford garage may try to sell steel ones.
Old Oct 25, 2007 | 04:50 PM
01 superduty
I did take the manifolds off, it makes it easier and you need to put new gaskets on also, pretty easy job.
Old Oct 25, 2007 | 05:09 PM
dkf's Avatar
dkf
My studs and my dads studs were stainless from factory. Rust was not the issue, they were shearing or snapping off.
Old Oct 28, 2007 | 08:28 PM
99f53's Avatar
99f53
I pulled both my 99 F53 manifolds, had total of 7 out of 20 studs broken flush with the head. I put on a Banks system rather then reinstall the stock manifolds. Big difference in heat dissapation, fan clutch never engages now.
jagrote
23
Oct 12, 2016 12:20 AM
jagrote
17
May 29, 2016 11:46 AM
CNC
Sep 5, 2015 09:12 AM
canbman
Exhaust Systems
Nov 4, 2003 01:23 AM
steveoh
1997 - 2003 F150
May 8, 2002 12:42 PM
