InJectors
Old Oct 24, 2007 | 06:46 PM
kawa's Avatar
kawa
InJectors
My '97 PSD came stock with Split Shot Injectors (Cali) If I put Stage 1's in do I have to stay with split shot?
Rog
Old Oct 24, 2007 | 07:06 PM
plowhand's Avatar
plowhand
Playing in the Dirt
No, you can have your PCM reflashed for singles. I think, but I don't know for sure, that a custom chip can also change the programming to singles. Someelse with more knowledge should be along to answer for sure. Or you can call Tony or Jody and ask them.
Old Oct 24, 2007 | 07:12 PM
glasseater's Avatar
glasseater
plowhand is right you can have the PCM reflashed to work with singles, or you could just go with custom programming from tony or jody
Old Oct 24, 2007 | 08:56 PM
tjbeggs's Avatar
tjbeggs
I would single shot then either a reflash or a chip will be need to run single shots.
Old Oct 25, 2007 | 07:30 PM
powerstroked162's Avatar
powerstroked162
Why not go with split shot 1's?
Cowboy Steve
Old Oct 25, 2007 | 07:32 PM
c00nhunterjoe's Avatar
c00nhunterjoe
cause split shots wont make the power the singles will, and they use more fuel to get the same power levels
Old Oct 25, 2007 | 07:36 PM
powerstroked162
Is he building for power? Im just talkin to talk but I would think that split shots would be cheaper it seems then gettin singles and new PCM...
Cowboy Steve
Old Oct 25, 2007 | 07:51 PM
FFemt5287's Avatar
FFemt5287
theoretically, to get any power out of the stg I splits he would need a chip neway. he might as well go ahead and get singles and spend the same amount of money on he chip to run singles.
