intercooler finished on sunday...
Old Oct 24, 2007 | 04:40 PM
glasseater's Avatar
glasseater
finally got around to uploading some pics, they're all from my phone, so are the videos, but the quality is still pretty good.... check em out!!!
http://s21.photobucket.com/albums/b2...ler%20install/
the videos are pretty sick haha
Old Oct 24, 2007 | 05:20 PM
c00nhunterjoe's Avatar
c00nhunterjoe
looks good, alot of shots look familiar.......
the hole you asked about is a boost fitting
Old Oct 24, 2007 | 05:42 PM
glasseater's Avatar
glasseater
that's what i figured it was for but why would i put a boost gauge before the intercooler... the point of a boost gauge is to measure MANIFOLD pressure not necessarily turbo pressure... i guess i could always throw another boost gauge in for fun though
Old Oct 24, 2007 | 06:00 PM
c00nhunterjoe
hook your map sensor line in there instead of its current location and become amazed at the difference
Old Oct 24, 2007 | 06:49 PM
plowhand's Avatar
plowhand
Playing in the Dirt
What tubing kit did you use?
Old Oct 24, 2007 | 06:56 PM
glasseater's Avatar
glasseater
banks, i heard good things (from other banks haters) and it was on sale so why not? lol
Old Oct 24, 2007 | 06:58 PM
glasseater's Avatar
glasseater
but that wouldn't be the pressure that's worth looking at... you want intake manifold pressure, that's the pressure that should be worrying you...
if i was to hook another boost gauge into that location where could i run it?? would i just plug the end??
Old Oct 24, 2007 | 07:00 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I really like your set up, where did you buy the IC and costs? you should change your pyro to pre-turbo position. where did you put the tranny cooler?
Old Oct 24, 2007 | 07:02 PM
glasseater's Avatar
glasseater
the kit was from banks, it was on sale for the price of other intercoolers... about 1300... the sale is over now though, the tranny cooler is under the radiator, you can barely see it in one of the pics
Old Oct 24, 2007 | 07:03 PM
glasseater's Avatar
glasseater
and yes i want to move my EGT sensor to pre turbo but i was planning on doing that when i get a new turbo (may need a new downpipe for that so perfect time to switch)
plowhand's Avatar
plowhand
Playing in the Dirt
By hooking the map sensor in the spider it lets it see the boost sooner. The PCM dumps fuel as the boost increases, the longer it takes for the map to read a boost increase the long it takes for the PCM to siganl more fuel: Thus the dreaded "BOOST LAG".
Move your map sensor, you'll be glad you did. Just ask TJ.
Old Oct 24, 2007 | 07:11 PM
glasseater's Avatar
glasseater
i don't have any more boost lag than i did before the intercooler... TJ is running smaller injectors, i doubt it will make much of a difference with my stage 2s... and if i did run the map sensor line to that point (which i might just to see the difference) then where could i put the boost since i want useful boost pressure readings not the pressure coming out of the turbo... and also if it reads boost sooner than it will dump more fuel than necessary earlier, which will be pointless... the air will not have reached the intake manifold by the time the extra fuel is dumping in... if i understand what you're saying correctly... it seems like it would do more harm then good... higher EGTs with no performance benefits... (that i can see)
Old Oct 24, 2007 | 07:16 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Thank you glass.
Old Oct 24, 2007 | 07:23 PM
glasseater's Avatar
glasseater
Thank you glass.
the only thing i don't like about it is that it's a REALLY tight fit underneath the a/c condensor line... i loosened the a/c condensor to get it in...
Old Oct 24, 2007 | 07:31 PM
Aireeek's Avatar
Aireeek
What transmission coller do you have in there?
