2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
2007 expedition will not start!!!
Old Jul 6, 2017 | 02:55 PM
mctwist311's Avatar
mctwist311
07expe crank no start full for scan csv
https://drive.google.com/file/d/0B1IndAFy2gIrdmViYjR3d1FwemM/view?usp=drivesdk
So I've tried everything. I have over 40 psi fuel, that's as high as my gauge goes. Spark, and have replaced crank and can sensors. From time to time it starts but will most definitely leave me stranded. Replaced the battery Aswell here is a scan of my most recent time I got it running from forscan I am hoping that someone with experience using forscan can tell me what might be the issue. Thanks in advance. https://drive.google.com/file/d/0B1IndAFy2gIrdmViYjR3d1FwemM/view?usp=drivesdk
Old Jul 7, 2017 | 09:22 PM
charlesmoody67's Avatar
charlesmoody67
Battery checked. New master fuse junction box. Did 10 minute reset. Did 3 minute heater switch unplug. Cleaned all battery lines/connections. Cleaned all starter/solenoid contacts.
Tried with battery jumpstarter connected to fully charged battery. Still same outcome.
Starter relay clicks once. traction light on / anti-theft light blinks 8 times when turn the key / fuel lite------- / --------miles light / No turn over full power starter relay single click on 2007 ford expedition el limited
Old Jul 7, 2017 | 10:07 PM
charlesmoody67
07 expedition el limited still won't crank. Lights don't go down(battery good) when you turn key to crank. have anti-slip / battery / oil lamp / security / and wrench lights on dash warning system after you turn key to crank and you get 4 chimes. Still all you get is one click from starter solenoid. Could it be security system?
Old Jul 8, 2017 | 09:35 PM
mctwist311's Avatar
mctwist311
Charles check for 12v at fuse 46, and swap corresponding relay below with a known good one. Sounds like your ecu is not powering up
Old Sep 28, 2019 | 06:05 PM
Eddie Gonzalez's Avatar
Eddie Gonzalez
Did you ever get this figured out? If so, what was the issue?
Gryphon1962m
22
Apr 24, 2022 11:27 AM
Powerstroke_99
21
Dec 24, 2017 08:22 AM
mcguirkp
Mar 28, 2017 09:00 AM
James Hogan
Feb 17, 2017 08:18 PM
K9jnr
Jul 10, 2016 10:06 PM
