E40D and Four Way Flashers
Old Oct 24, 2007 | 10:14 AM
greg_garlow's Avatar
greg_garlow
Hello All,
We have a 1995 F350 diesel with 75,000 miles which is relatively new to us (bought two months ago). Going over Raton Pass (I25 southbound) with our fifth wheel the transmission front seal let go. Fortunately it let go at the top so we could coast into Raton. We're reworking/upgrading the transmission in Trinadad. The transmission guy confirmed that the unit has been worked on several times in the past which maybe one reason the unit was sold. He also was adamant about NOT using the four way flashers on hills as this causes intermittent disenagement/engagement of the torque converter. I found another thread in another group which eludes to the same fact. Turns out we weren't doing this at the time of failure although I would have if our speed had decreased below 40 mph.
Given that its a good idea to announce yourself as a slow vehicle (an law in several areas) by turning on the four ways when speed drops this leads to several questions:
1. Why did Ford program the unit that way? On hills wouldn't you want the transmission always engaged independent of braking?
2. How can this "feature" be elminated so you can announce yourself as a slow vehicle and still keep everything under control?
Thanks
Greg Garlow
1995 F350 7.3L Diesel Dually
Old Oct 24, 2007 | 04:39 PM
Cuda_jim's Avatar
Cuda_jim
1. It is not designed that way
2. If you are going that slow the TC is not locked up anyway
If your hazard flasher IS affecting your TC it has a wiring problem.
Old Oct 24, 2007 | 09:18 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It WAS designed that way due to an oversight. Somewhere after 1995 (I forget exactly which year) Ford changed the programming to ignore the brake circuit input over 10% pedal.
The torque converter WILL lock at pretty low speeds if the go pedal is on the floor. In those trucks built before the change in programming the four way flashers would cycle the torque converter on and off and create A LOT of heat.
devildog197
May 21, 2014 10:01 PM
shotgunz
2009 - 2014 F150
Mar 6, 2010 09:19 PM
SC Silent Sam SOFWW
Mar 18, 2008 02:15 PM
The Frenchtown Flyer
1947 and Older Ford Trucks
Aug 12, 2007 10:21 PM
VikingBabe
Jun 3, 2005 02:30 PM
