04' Explorer Transmission issues
Old Apr 29, 2014 | 03:37 PM
devildog197's Avatar
devildog197
We have an 04' Ford Explorer NBX 4x4 (auto). We are not the original owners. It has a several issues.
1. Acceleration seems to be responding a little slow when I depress the accelerator pedal. Like a lag of some kind. Engine appears to idle and run fine. Just that subtle lag from gas pedal to engine response. No trouble codes
2. There is a tick or tap coming from behind the dash. This morning as soon as a put the key in the ignition the ticking started but went away after a few minutes on the road. But comes back when I come around turns (like a rounding off ramp from the HWY). Cant figure out what it is. No trouble codes.
3. My transmission (4x4 Auto) when cold is fine, but when it warms up it seems to go into 4x4 mode and wont come out. All I have to do start going up a subtle hill (or incline) and it engages the 4x4 (at least that's what it feels like). I can hear the sound of gearing. When the transmission shifts it thumps really hard. At low speeds when I let off the gas it thumps really hard. We took it to the tranny shop and they said it was the rear end. So we had that rebuilt. It was ok for a couple of months (rarely drive it). But it is doing it again, but seems to be getting worse. When in this mode it seems to feel like its draggin. We recently serviced the transmission filter. Replaced fluid. We reset the computer to relearn daily driving. But didn't help. I was thinking of replacing the 4x4 module and or solenoids in tranny, or 4x4 motor on transfer case, but I don't want to spend money if it doesn't fix the problem. No trouble codes.
Are all these issues related to one another? Is one issue causing the other problem to exist?
Can anyone help with advice and/or parts vendors? We really like our explorer and would love for it to be normal? LOL!
Old May 21, 2014 | 10:01 PM
whagen's Avatar
whagen
This is going to sound odd, but try cleaning the throttle body. Mine was acting similar and all it was was a dirty throttle body. Clean body side of the throttle valve. Get it back to clean metal. You may also want to change the egr valve.
If the throttle body is clean then its a different issue.
Tyler Michael
2004 - 2008 F150
Jul 17, 2019 05:15 PM
americanbuckeye
Aug 19, 2015 06:38 AM
ExplorerBob
Aug 15, 2010 10:03 PM
provost89
May 8, 2010 04:02 PM
dclement
Jul 24, 2003 04:49 PM
