turbo rebuild
Old Oct 24, 2007 | 09:39 AM
MapleShadeDiesel's Avatar
MapleShadeDiesel
turbo rebuild
does anyone know if i need any gaskets or o rings to put a new wheel in the turbo
Old Oct 24, 2007 | 11:00 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Just to replace the compressor wheel- Once it is on a bench, remove the 5 bolts holding the compressor to the backplate, hold the turbine wheel with a pair of vise grips on the end, and turn the wheel off with a 5/8" wrench. To do it right you should remove the turbo from the truck, however some people here have risked it and done it in the truck.
Old Oct 25, 2007 | 08:12 PM
MapleShadeDiesel
thanks for the info. who sells the gasket
Old Oct 25, 2007 | 08:29 PM
PowerstrokeJunkie
Gasket? For which part?
Old Oct 25, 2007 | 08:40 PM
MapleShadeDiesel
sorry I never played with a turbo before. I plan to take it apart this weekend to put a new wheel in it and want to make sure I have everything I need to put it all back together. I just thought there might be a gasket or o ring in there somewhere. I would hate to tear it apart and need somthing I can't ger right away
Old Oct 25, 2007 | 08:53 PM
PowerstrokeJunkie
Well to remove the turbo, you're going to at least need the two o-rings to seal up the connection at the turbo to the pedestal. While you are there, you should just replace the ones at the lower end of the pedestal at the block. So that's two small o-rings and two large ones.
Old Oct 25, 2007 | 09:00 PM
MapleShadeDiesel
Thanks for the help.
03_PSD
29
Feb 9, 2009 07:31 AM
airharley
Nov 19, 2008 07:42 PM
Jens
Dec 24, 2002 02:44 PM
powerstroker250
Jul 12, 2002 01:42 AM
hotrodmex
Mar 8, 2001 05:32 PM
