Duplicating keys
Old Oct 23, 2007 | 07:06 PM
thehawk75's Avatar
thehawk75
Duplicating keys
My Excursion only came with one key, and I'd like to get a duplicate made. However, according to the manual I need to have TWO keys in order to program a third. With only ONE key, I need to get the dealership to make me a second -- and the dealership is NOT cheap.
Is there any inexpensive way to get a second key programmed? Or must I bite the bullet and pay Ford for it ?
Old Oct 23, 2007 | 07:07 PM
cficare's Avatar
cficare
Bite the bullet.
Old Oct 23, 2007 | 07:31 PM
Stewart_H's Avatar
Stewart_H
Around here, locksmiths are more expensive than the dealership, but I've read that in other parts of the country, locksmiths are cheaper, so check them out too.
Either way though, yer gonna have to bite the bullet. No two ways about it.
However, once you do get your second key, buy a few spares from ebay (cost is around $6 dollars per for the plain ones) and have them cut for free at Orchard Supply Hardware, if you have one nearby. Then, once they're cut, you can program them yourself.
Stewart
Old Oct 23, 2007 | 07:32 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
If you bought it from the dealer, they should spring for a second key & programming. Should get it done anyway - PO has a key that will fit...at least if you have second key made & reprogrammed, original key won't start the vehicle anymore. It WILL open the doors tho......
Old Oct 23, 2007 | 07:36 PM
Stewart_H's Avatar
Stewart_H
Not true, the keys will still start the vehicle.
The PCM would have to be reprogrammed along with a new set of keys in order for the previous owners keys to be non-op.
When you get a spare key from the dealership, they aren't being reprogrammed along with the PCM, they're just being programmed to be compatible with the PCM (which is still in the vehicle) so the key can start the vehicle.
Stewart
Old Oct 23, 2007 | 07:50 PM
shadows4's Avatar
shadows4
I had to have a second key made when I bought my Excursion. Locksmith was much cheeper than dealer. Bought my key blank of E-bay then had locksmith cut it and program it. Took about 45min and $50. Then bought another key to it to Wal-Mart and they cut it for free, went home and programmed the third key myself. John
Old Oct 23, 2007 | 07:59 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Stewart
Wrong - when the dealer reprograms, ALL key codes are erased, then the key codes of the two keys in hand are programmed in. The "missing" original key will no longer start the car. At least thats the way its supposed to be done. Usually takes about 1/2 hour to erase - reprogram. (Thye key isn't reprogrammed, the key code is programmed into the PCM).
Old Oct 23, 2007 | 09:04 PM
FordCrusherGT's Avatar
FordCrusherGT
Bite the bullet. I just paid the Ford dealer $200 to have a new key and new remote made and programmed for me, my Excursion only came with one as well. The key was $150, and the remote was $50. Yeah, it's not the cheapest solution, but it's easy and then you've got two separate sets.
Interestingly enough, Mercedes key/remote things are only $125, at least on my boss's C43. Go figure.
Old Oct 23, 2007 | 10:21 PM
Stewart_H's Avatar
Stewart_H
Your above post that I've quoted is correct. And that is essentially what I posted when I corrected your first post in this thread, because your first post did not correctly state what I quoted above. (huh? whatd he say?? who's on first???)
Bro, you need to read what you ORIGINALLY posted, and my response to it. I even quoted it in my post for clarification. Since you didn't understand, I'll try once more.
You stated "if you have second key made & reprogrammed", well, if a dealership reprograms a second key, it won't match the first key. But if a dealership PROGRAMS a second key for you, it will match the first key you have in your possession.
So a dealership won't REPROGRAM a second key for you. They will however PROGRAM a second key for you.
Dealerships can also program a new PATS code into a set of keys, but that also means reprogramming the PCM. That will render any other keys that used to start the car useless.
On top of all that, a PATS key would have to have a program already on it in order to be reprogrammed. If it's blank, then the key is being programmed, not reprogrammed.
Stewart
PS - That first paragraph above was not easy for me to compose, and it's even harder to read! LOL!
Old Oct 23, 2007 | 10:35 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by FordCrusherGT
...and the remote was $50. Yeah, it's not the cheapest solution, but it's easy and then you've got two separate sets.
Ebay for that second or third remote, guys.
They usually go for $10 to $15 bucks, and they are a snap to program yourself.
Stewart
Old Oct 24, 2007 | 03:59 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
Stewart
But you keep missing the point, KEYS DON"T GET REPROGRAMMED. At least thats what I've been told.
Old Oct 24, 2007 | 07:01 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
That's true. The key is a transmitter. The programming is to teach to PATS system to accept the keys.
Old Oct 24, 2007 | 10:03 AM
2manykids's Avatar
2manykids
Then can you reprogram the program of the PCM to link the transmitter that will remote start my brain again sense the overload that was cased by the deprograming of said brain?
Old Oct 24, 2007 | 11:38 AM
Beerstalker's Avatar
Beerstalker
The keys have a built in chip that sends out the same signal for the entire life of the key, it can not be changed.
When you program the vehicle to accept another key you are programming it to accept the signal that key puts out, you are not changing the signal from the key.
Just like when you program a new keyless entry remote, as soon as you enter the programming mode all previous codes are erased. You have to have all the keys (or remote keyless entry keyfobs) that you want to work with you or they will not work after you finish the programming process.
So technically if you had a key that worked in two different vehicles (because the cut on the key is the same) you could also program it to work in both vehicles since the PCM is what does all the work, they key has no idea what vehicle it is in.
Old Oct 24, 2007 | 03:02 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
All true. And when the dealer reprograms with 1 old and 1 new key, those are the only keys that will start the vehicle. The "other old key" will still unlock the doors, but will no longer start the vehicle as I stated before. All the more reason for the dealer to try and get all the keys on a trade in.
