Hard Shift, OD light flashing
Old Oct 23, 2007 | 02:34 PM
Cofooter's Avatar
Cofooter
I've read a lot of the threads on here on this subject and know you guys are going to tell me to get the codes read. I've been trying to locate someone within 30M to get this done (Autozone was no help) and I'm still looking. In the meantime though, here are my symptoms. By the way 2001 F-250 automatic with 113,000 miles.
Light starts flashing once I put the truck into reverse or drive after starting.
Somewhat hard shift from 1>2 and 2>3, 3>4 seems fine. not really bad, just harder than before.
Speedo is looking like it is reading fine.
This started after the last time I towed a boat and used the overdrive off mode. Didn't happen before that.
Unhooked the battery cables to re-set the computer - no difference.
Its been awhile since I serviced the transmission (don't recall the last time). Would it be wise to start there until I can get the codes?
Any suggestions for right now?
Thanks
Old Oct 23, 2007 | 04:26 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I think that would be a good place to start. Change the filter while you are at it.
This should bump it to the top. Good luck
Old Oct 23, 2007 | 06:58 PM
clintbonnie's Avatar
clintbonnie
Thanks
You should really change out the trans fluid, including the torque converter and trans filter every 36K or sooner..
My OD light was flashing and it turned out to be a VSS sensor on the top of the rear end.. Napa sells them for $10.49.. p/n 530780 (they call it a ABS sensor) .. see: www.napaonline.com
Old Oct 23, 2007 | 11:11 PM
Cofooter's Avatar
Cofooter
OK, thanks for the ideas guys. Would the VSS make a difference if I did not notice anything wrong with the speedo?
Old Oct 26, 2007 | 03:23 PM
Cofooter's Avatar
Cofooter
Aamco scanned the transmission codes for free for me today. Looks like code 705/708, transmission position sensor otherwise known as the Neutral Safety Switch I am told. It should also fix the problem I am having with starting (having to wiggle the lever) to get it to turn over. I think I dodged a bullet financially on this one.
Old Oct 26, 2007 | 03:29 PM
miller_feed
Sounds like you did, easy fix is soooo good.
Glad you found the problem.
u264474
Dec 12, 2014 01:08 AM
bettyford93
31
Dec 2, 2014 08:52 AM
Scruffy
Oct 6, 2012 12:03 AM
kidd_76
Apr 7, 2010 07:54 AM
