Trans is jumping
Old Dec 10, 2014 | 03:44 AM
u264474's Avatar
u264474
Trans is jumping
My 96 f350 7.3L has been giving me fits since last year. I have a plow on it and used it a lot last year with all the snow. It started to shift really hard in about 2nd gear. it was a high rpm then slam into gear. After that time my speedometer, tachometer, interior dome lights and high beams all went out. As well as not able to start from yhe ignition. My o/d light flashes. Now its really bad. The truck cannot seem to recognize the gears and 4x4 doesn't seem to be engaging right. I was having a problem where if I put it into 2 high at a stop the truck would jump and die out. Now the needle to identify the gear on the column broke. I'm almost shifting blind but when I'm in park the truck sometimes goes into reverse. It sometimes seems as if the shifter is off 1 to the right. I've been reading the forums and will check the TSS as well as the fuses. Most of my friends are telling me to get rid of the truck but I'm convinced its not a major trans problem. I'd like to prove them wrong. Please help
Old Dec 10, 2014 | 08:52 AM
oldbird1965's Avatar
oldbird1965
Wow, that's a lot of stuff going on! Maybe Mark, our trans guru, will chime in. Welcome to the forum and I hope you can prove your friends wrong!
Old Dec 10, 2014 | 09:07 AM
Fordman96's Avatar
Fordman96
I remember my o/d light flashing on my gasser. I was told it was a bad sensor, but I got the whole trans rebuilt for $1500 from a local shop
Old Dec 10, 2014 | 12:03 PM
madpogue's Avatar
madpogue
If the OD-OFF light is blinking, there's a code stored. Is the speedometer still inop? Does the odometer display a number, just one that doesn't change? Or is the odometer blank?
Old Dec 10, 2014 | 02:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you read enough you would have learned that a '96 doesn't HAVE a TSS. You might mean VSS (Vehicle Speed Sensor) and you do have one of those on the rear axle. I doubt that is your problem.
With all of the electrical things that quit working it's no wonder your electronically controlled transmission is having problems. Find and fix the electrical issues and I'm almost certain the trans will be fine again.
If you get the codes read you will have a starting place to begin the diagnosis. The places that read codes free CANNOT read these codes. You need either a good independent shop or a Ford dealer.
Old Dec 10, 2014 | 05:59 PM
madpogue's Avatar
madpogue
Or your own device known to be capable of communicating with our trucks (which is what a LOT of us choose to use).
Old Dec 12, 2014 | 01:08 AM
Thor'sHammer's Avatar
Thor'sHammer
You can get a snap-on MT2500 for about $100 now with everything you need to connect to the truck. I'd look into that route.
Jn11470301
Jan 6, 2013 09:52 PM
hey172
1978 - 1996 Big Bronco
Nov 11, 2012 11:34 PM
hughjazz
Sep 6, 2009 06:11 PM
Bronk351
Jul 14, 2009 08:48 PM
cracked lp
Jun 18, 2009 10:57 AM
