Turbo Tubes
Old Oct 28, 2007 | 11:54 PM
78F150XLT's Avatar
78F150XLT
well i want my truck for all waht you listed, mostly drags but yet i can off raod with it and dirive it everyday and nothing will break or fly appart... i want alot of boost off the bottom end like at a lower RPM so i can have a really good hard launch. and powergoals, the most i can get with out blowing it appart! hahaha the truck is a 95 F150, 4x4, 3inch body lift/4inch supention, 4:10 gears, lockers both front and back, 35X12.5X15 Baja MTZ tires, full function ram air hood, 302 V8 with headers, cam,thorttle body spacer, airfilter, electric fan, 3inch exhaust with high flow cats, E4OD tranny with stage 2 shift kit, B&M truetrac, and thats pretty much it beside my steareo... what else you wanna know?
Old Nov 12, 2007 | 08:30 PM
fordtruckguy31's Avatar
fordtruckguy31
any pics of it so far? a turbo would be cool
Old Nov 13, 2007 | 12:04 AM
78F150XLT's Avatar
78F150XLT
well I kinda put the plan on highatus because well I think it would be kind of a bad idea... considering having a boost controller in the cab and the max PSI for the turbos at a high enough pressure to split my crank in 2 and blow appart my motor... I'll let you know if i go with this idea or if i just run aluminum heads/intake on a 331 stroker.... that one intrests me awell... but the turbos would be comming from ebay and would take a while to come and everything... Quick question, Can you use 3inch Flex tube for the down pipes to the exhaust? my brotehr used 3.5 on his desiel for where the muffler went, wondering if you can do the same for this?
Hihihidude13
Jan 25, 2020 01:53 PM
Yeehaw1
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jun 25, 2013 08:27 PM
dyingtolive
48
Sep 19, 2012 01:49 PM
78F150XLT
Alberta Chapter
Oct 31, 2007 11:47 AM
blake 7.3L
16
Jan 31, 2007 07:57 PM
