Cant Find Hedman Headers
Old Dec 22, 2002 | 06:44 PM
Boss300's Avatar
Boss300
Old Dec 27, 2002 | 09:21 AM
Ford204x4's Avatar
Ford204x4
I hear you guys talking all about the hedmans. But I cant find. Does anybody know the part#??
Old Dec 27, 2002 | 10:12 AM
tetraruby's Avatar
tetraruby
Welcome to FTE. I'm not sure if this is PAW's number or Hedman's, but for a 2WD - 89300 is the number from PAW.
Old Dec 27, 2002 | 10:20 AM
Ford204x4's Avatar
Ford204x4
I need to say it a 5 speed too. I beliave 2 and 4 headers have dif angles.but thanks
Old Dec 27, 2002 | 02:30 PM
82F100SWB's Avatar
82F100SWB
for 80-96, the chassis is the same between the 2wd and 4wd, I had no problems with the Hedmans on my 300 with the truck set up either way.
With the 300, what tranny you have doesn't make too much difference, as the clutch linage, or shifter linkage is on the opposite side of the engine.
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Old Dec 27, 2002 | 02:56 PM
Ford204x4's Avatar
Ford204x4
Yes but whats the item #. or were did you find them.
Old Dec 27, 2002 | 05:03 PM
ftwfred's Avatar
ftwfred
Originaly posted by tetraruby
"""Welcome to FTE. I'm not sure if this is PAW's number or Hedman's, but for a 2WD - 89300 is the number from PAW.""
ftwfred
Old Dec 27, 2002 | 06:15 PM
Silver Streak's Avatar
Silver Streak
[updated:LAST EDITED ON 27-Dec-02 AT 07:17 PM (EST)]The number posted above sounds right. When you look up the application it won't show the headers to fit anything past 89, but they fit all the way up to 96. At least that's how it was when I bought mine. Here's the link to Summit's listing:
http://store.summitracing.com/partdetail.asp?part=7075
The listing says 2wd only, but I've compared my truck (1990) to an 89 4x4 and couldn't see anything to keep them from fitting the 4x4.
