popping six..
Old Dec 27, 2002 | 11:43 PM
ford_nut's Avatar
ford_nut
popping six..
OK guys
I need some help here. I posted earlier about a 300 six that pops while it runs, I checked to see that all the plug wires are intact. I also checked to see if the firing order and distributor timing is ok. Without pulling the dizzy, everything seems OK. When it runs, it pops out of the carb on a regular basis--like every sec or so. Also, when i go to start it, it sounds as if the compression is uneven...
Im starting to think that there is something amiss in the head. Can someone give me an idea where to start troubleshooting before i start ripping stuff apart unnecessarily? would a burnt intake valve cause this? I dont think a 300 has a timing chain to jump per se. i am really at a loss with this one here! HELP!!
regards
~~NUT~~
Old Dec 27, 2002 | 11:47 PM
Martys82's Avatar
Martys82
popping six..
bent/burnt valve
Old Dec 28, 2002 | 07:09 AM
ftwfred's Avatar
ftwfred
popping six..
Start with a compression test...This will tell you MUCH about your engine condition...
A vacuum guage does wonders too>>>>>
ftwfred
Old Dec 28, 2002 | 12:16 PM
Ford_Six's Avatar
Ford_Six
popping six..
I wouldn't say a burned valve- very rare on the intake. Most likely, head gasket between #3&4.
Jared
Old Dec 28, 2002 | 03:11 PM
heathdaily's Avatar
heathdaily
popping six..
Does the popping occur with regularity? Or does it do it sporadically with no pattern? If it's sporadic it could be a sticky valve. Either from lack of oil or carbon build-up.
Old Dec 28, 2002 | 04:24 PM
ford_nut's Avatar
ford_nut
popping six..
guys
the popping is very regular. If i do a compression test, what should I be looking for? low #'s? ect??
Old Dec 29, 2002 | 02:50 PM
Chas1234's Avatar
Chas1234
popping six..
Check to make sure a rocker arm didnt loosen up on one of the valves.
This happened to me with a 1978 300 and I didnt find out what the problem was until I pulled the engine to put in a rebuilt short block !
good luck, Jon
'75 F100 4X4
"89 F150 4X4
Old Dec 29, 2002 | 06:42 PM
Farm Dog's Avatar
Farm Dog
popping six..
Joshglov
49
Jan 9, 2019 12:31 AM
krwagn01
Apr 5, 2014 12:41 PM
bronco power 79
1978 - 1996 Big Bronco
Nov 2, 2011 05:24 AM
LIF150
Sep 12, 2011 03:59 PM
cmachk
Oct 12, 2007 07:39 PM
