Difference between '06 & '07 5.4 heads
Old Oct 21, 2007 | 08:17 PM
Powerws's Avatar
Powerws
Just concerned with the plug issue! Did they make a change between the '06 & '07 Heads. I heard that prior to '07 that the plugs blew out! Has anyone had, or heard of this happening to a '07 & '08 5.4 Triton?
Old Oct 21, 2007 | 10:34 PM
DRM2004's Avatar
DRM2004
No plug blow out issues on the 5.4L 3V....but you'll read lots of nice stories about plugs being broken when attempting to change spark plugs. Do a search you'll see. In summary, changing the plugs long before the 100k mile recommended interval seems to help (~50k or less)...follow the TSB (technical service bulletin). I changed mine at 41k with no issues.
There has been no head design changes from 2004 to date....except for some minor cam phasor changes between 2004 and 2005.
The plug blow out issue was occuring on some pre-2004 (2V engines).
Old Oct 21, 2007 | 11:17 PM
KevinAH's Avatar
KevinAH
After being told to wait until I absolutely have to by the Ford dealer, I was told by the same person that it's probably a good idea to remove the plugs every 30k and apply anti seize on them. This is after I paid a chunk of change to have 6 broken plugs extracted. Just an FYI-not sure if it will actually solve the sticking issues.
Old Oct 22, 2007 | 12:11 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
apparently the 07-08 also have headers vice normal exhaust manifolds like the 04-06 models
may have to get me some of those
Luckett35
Modular V8 (4.6L, 5.4L)
Jul 28, 2016 05:36 PM
COOLRAUL64
Computer Chips & Tuners
Mar 17, 2016 09:19 AM
Flatbed79F250
2004 - 2008 F150
Jan 19, 2016 07:27 AM
22fordguy
May 14, 2015 10:07 AM
rcrowder
2004 - 2008 F150
18
Feb 14, 2007 06:11 PM
