hey when you put the crimp ends on use the ones with shrink tube on them and put solder in from the side that goes on the coil for a strong connection and no corrosion.
update checked the resistor its okay that plug thats a little melted wasnt causing my problem either im just not getting any power to the coil unless i run a wire from the battery dont know why and when i run a wire from the battery all im gettin is a weak yellow blue spark
turned out autozone gave me a bad module went got another one plugged everything up and i was sparkin and gettin power to the coil it was still a yellow spark but i think i might have fried my new starter coil again too with that wire i had ran to it and me constantly turning the engine over it stayed so hot it would burn the crap out of you my advice is never get anything from autozone i just looked on every part that i bought from there and it all has the same death words "Made in Mexico"
no mexico my battery also probably why it isnt worth a crap i would rather go pay double the price somewere else and get a good part than ever buy something from autozone again and if i do im gonna somehow make them prove to me that it works before i walk out the door with it lol im gonna take this coil back and theyd better replace it its there fault it went bad again in the first place if they would have gave me a good module if they dont take it back somebodys gonna be walkin funny with a starter coil hanging out there @$$
get the battery from wal-mart and DO NOT ask what battery it uses . 56-5 always go for more than you need like the 1000ca everstart maxx 65-n. Anyone know what i need to set up a 5 battery system the main battery plus four batteries for accesories like two amps,CB,12volt cooler,extra lights and inverter.
want to thank yall on the help on fixin the beast just took it out on the road the first time it is missing a little due to a worn rotor ill pick one up tommrow but that thing is a beast with those straight pipes
I got another ? where can i get a different air filter setup i dont like the one im with now hoping someone can point me to a site with some dressup mods
