tranny fluid
Old Oct 21, 2007 | 03:56 PM
darascal's Avatar
darascal
tranny fluid
I just changed the fluid and filter in my 1997 ford ranger w/175000 mile 3.0liter v-6 auto tranny the problem is I was supposed to use Mercon5 instead I used a Mercon compatable product. What is the best way to deal with this since it has been ran and is now mixed. any help would be very appreciated
Old Oct 21, 2007 | 05:35 PM
darascal's Avatar
darascal
my main question is do i need to worry about a complete fluid change (torque converter) or can I get away with the standard oil and filter change
Old Oct 22, 2007 | 09:10 AM
jimdandy's Avatar
jimdandy
Not all transmissions used Merc V in 1997. This site might help:
http://www.txchange.com/merconv.htm
jd
Old Oct 22, 2007 | 05:05 PM
darascal's Avatar
darascal
THX JIMDANDY unfortunatly I had already confirmed I used the wrong fluid now I wondering howe I go about getting ALL the wrong stuff out before I have a problem
Old Oct 23, 2007 | 03:59 AM
PW01's Avatar
PW01
You'll have to take it to a shop and have it flushed
Old Oct 23, 2007 | 07:47 AM
Rockledge's Avatar
Rockledge
Even then, you 'll want to confirm beforehand that the shop is going to be putting Mercon V in there.
Jim, Ford now recommends Mercon V for ALL applications that previously called for regular Mercon.
See: https://www.ford-trucks.com/forums/s...65&postcount=1
There's still a lot of leftover Mercon stocked on shelves so that's why you still have to be sure that the fluid that is going in your tranny is actually Mercon V.
Old Oct 23, 2007 | 09:50 AM
blue beast's Avatar
blue beast
You can buy stuff that converts old mercon to mercon v http://www.transmissionpartsusa.com/...-000062005.htm
It will save the trouble of re flushing and you still might want to add it if you do flush
to convert the left over to mercon v!!
Old Oct 28, 2007 | 08:51 AM
7622RM's Avatar
7622RM
Darascal, you can check out this link to do a pretty good flush on your own: https://www.ford-trucks.com/forums/6...ighlight=flush
mxracer3276
Feb 27, 2009 01:29 PM
JFUSION
Escape & Escape Hybrid
Nov 21, 2006 08:34 AM
qdude79
1997 - 2003 F150
May 10, 2006 08:02 AM
Joel Steven
Aug 30, 2005 09:39 AM
50stang
Oil & Lubrication
Feb 21, 2005 07:43 AM
