trouble code PO340
Old Oct 21, 2007 | 09:15 AM
go boy go's Avatar
go boy go
Exclamation trouble code PO340
hey folks, im new to this forum but a long time viewer of this site, lots of knowledgeable people, My problem is with my 2003 f-150 V-6 standard cab 2wd 5speed. AutoZone ran a test and gave me the results of a bad CAMSHAFT POSITION SENSOR. check engine light came on so I had it Checked. At first the engine acted like a bad plug wire, it would miss at times under accleration, then yesterday (sat) it ran like crap, like on 3 cylinders but if you acclerated it would run good at higher rpms, then it ran fine. I diconnected the battery to clear the codes and the check engine light went out, so i went back to AZ to have the check redone, when I started the engine, the light was back on, engine runs ok, misses at times, but does not run bad, but got the same good news about the CPS. where is this jewel located on this engine, is it external or internal, any pictures of where it is ? and is there a good online store to purchase this item. I look forward to hearing from you!!! Thankyou ,Tony
Old Oct 21, 2007 | 09:20 AM
Ultramagdan's Avatar
Ultramagdan
Great to have you here Tony!
That is a common topic in the tech forums so you will want to check in them. I suggest trying this one: https://www.ford-trucks.com/forums/forum25/ or the engine forum: https://www.ford-trucks.com/forums/forum48/ The folks in either of those boards can fix up.
Also checkout your state chapter when you get a chance: https://www.ford-trucks.com/forums/forum80/
Good Luck!
DiggerE2
New Member Introductions
Dec 23, 2017 09:30 PM
Bigbiky
Apr 27, 2013 12:30 PM
BryanRR59
Apr 16, 2008 07:26 PM
