How much would you pay for a....
Old Oct 20, 2007 | 11:27 PM
dirtjumper01's Avatar
dirtjumper01
1977 Ford F-150 4x4 Ranger XLT. Automatic trans. 40k On 351M rebuild, Posi in rear, trans cooler and some other little things. Perfect drivetrain and rust on rear quarters and left cab corner.
Here are pics:
thx
Old Oct 20, 2007 | 11:37 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Looks like the seller replaced the ratty outside mirrors that were shown in the first two pics. They are factory also, but the arm, at least on the right side was bent.
Old Oct 20, 2007 | 11:42 PM
dirtjumper01
So, what would you pay for the truck, if you were to buy it?
Old Oct 21, 2007 | 12:22 AM
masterbeavis's Avatar
masterbeavis
My rule of thumb is that ANY running driving 4X4 is worth at least $1000, unless the body is completly hammered, and barely runs. Where I live, I would give about $1500 tops for that truck minus the body rot. I would pass it up and find something that needs nothing. However, where I used to live, I would pay the $1500 for it because I would know I'd have to pay more money for a truck that did not have rot, because those are impossible to find. Also, having rot was a normal thing. Look in your local papers, and see what trucks of this vintage sell for, and make the offer (or set the price) accordingly.
Are you the seller, or thinking about buying it?
[edit] I just looked at your gallery, this is your truck before you took it apart. I don't get what you are trying to figure out, how much it was worth before you took it apart?
Old Oct 21, 2007 | 12:57 AM
projectdagger's Avatar
projectdagger
i'd say, 1,500 dollars.. It looked like it was in good condition when it was bought. Looked at the restoration pictures, it is coming along quite nicey
Old Oct 22, 2007 | 01:12 AM
NumberDummy
I wouldn't buy this or any regular cab. Not because I don't like the cabs, but at 6-5, 335 lbs. There's NO way I can fit in one.
I wouldn't even guess what it's worth without a thorough inspection. Trucks like this WITHOUT rust are a dime a dozen here in SoCal, and can be bought for less than 2 grand.
My neighbors gardener just bought a 1976 F100 Styleside (360/C6) with original red/white paint for $800.00 from an ad he saw in the Penny Saver. It's not perfect, but the body is straight and the interior is decent.
Old Oct 22, 2007 | 01:53 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
$500 tops. But thats just me. If theres a bunch of money put into it and there are receipts to back it up maybe more. Overall theres not much of value to me. Its an early 77 at best, non-a/c cab, has rust (check the cab mounts), aside from the XLT stuff there isnt much of real value.
Old Oct 22, 2007 | 03:56 PM
balingwire's Avatar
balingwire
Just based on the pictures, if it's worth anything, it's worth $1500. That's just the way it is for these trucks. If the frame is not ate up with rust - look for big flakes, check the crossmembers under the bed, the rear shock mounts - also if all of the lights in and out work (you can over look a shot bulb outside or in the instrument panel, as long as nothing funny happens when you press the brake pedal or turn the blinkers on) and it runs, shifts, and drives good, it will be worth $2000-2500 to someone, and that's not bad. I'd go $2000.
Old Oct 22, 2007 | 04:44 PM
dadstan76's Avatar
dadstan76
$500, I got mine for $350
Old Oct 22, 2007 | 05:24 PM
X36's Avatar
X36
For some reason I pictured you as a demure/bespectabled/sm guy that really liked books.Guess I was wrong HUH
Eagle460
May 21, 2008 04:34 PM
dirtjumper01
45
Jan 21, 2008 08:28 PM
dirtjumper01
35
Oct 31, 2007 05:45 PM
Alpineer
Appearance & Dress-Up
Oct 9, 2007 10:34 PM
dirtjumper01
27
Jun 11, 2007 03:11 PM
