400 2v heads
Old Oct 20, 2007 | 09:30 PM
Dmford's Avatar
Dmford
400 2v heads
Well I am almost there. I have the 400 short block built and ready to go. I had bought some used heads that have been ported, valve job, they have some titanium retainers. The port work looks good and the heads look good over all, but heres the thing they have multi groove valves. From what I have found these are no good. I was thinking of stainless valves. What do you think.
Old Oct 21, 2007 | 10:13 AM
lucky no. 7's Avatar
lucky no. 7
yes, hose multigroove retainers are known for coming out of the valve notches at higher rpm, clevelands share that stroke of bad luck with the 3.8 v-6's too,
Old Oct 21, 2007 | 12:25 PM
danlee's Avatar
danlee
I don't think that the multi-groove valves are that bad. I ran a set for a few years on my 400 with no problem. 400s don't normally rev like a Cleveland.
Stainless steel valves are a good idea, however.
Old Nov 19, 2007 | 06:10 PM
LedheadELH's Avatar
LedheadELH
yea, those valves are only bad for clevelands.......because clevelands are always, or should be built WAY too nasty for the street. lol, but seriously, clevelands are high revvers. Hence the big block style heads on a motor w/ small block displacement. Those 2V heads are an identical casting to the original heads for your 400. If they are ready to go, and slightly ported, I say go for it!
Old Nov 19, 2007 | 07:54 PM
Dmford's Avatar
Dmford
Thanks for all the help. I have desided to redo the heads with ferrea valves and new guides also retainers and keeper. Some of the work was ok on the heads but I do not want to take a chance with dropping a valve. Thanks again. Cann't wait to see what this 400 is all about.
Old Nov 19, 2007 | 08:07 PM
danlee's Avatar
danlee
Most of the valve problems were from the two piece valves, not the multigroove valves.
The best bet is to go to the stainless steel valves.
1977mud400
May 21, 2014 10:03 AM
mustange70
Oct 13, 2011 01:31 PM
gordyn66
Aug 21, 2011 10:32 AM
slinger34
Nov 30, 2010 05:12 PM
1956f100
15
Jun 13, 2004 12:16 AM
