I need help
Old Aug 20, 2011 | 11:08 PM
gordyn66's Avatar
gordyn66
I need help
I have 79 F250 4x4 with what i thought was a 400m in it, I recently started to swap the 2 barrel manifold and carb for a 4 barrell, when i set the manifold in i noticed that the 2 center ports on the intake side of the heads are exposed. according to the part# on the manifold it's correct for the 351/400m, and the decal on the valve cover lists it as a 400 i'm thinking someone swapped heads at some point. How can i tell what the cylinder heads are?
Old Aug 21, 2011 | 02:27 AM
Slip ford man's Avatar
Slip ford man
You may get more reply's if you post your guestions in the forum for your year truck
1973 - 1979 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
copy the casting numbers on the heads, and re ask your problem there
Old Aug 21, 2011 | 03:42 AM
cj06's Avatar
cj06
those ports should be for the exhaust to pass across the manifold to help heat up the gas , carb ! your manifold should have come with some block off plates that fit in the holes to close them off !
Old Aug 21, 2011 | 10:32 AM
gordyn66's Avatar
gordyn66
Thanks realized after i posted it was in the wrong one.
gordyn66
Aug 21, 2011 10:42 PM
builtfordtough13
Jun 26, 2009 11:30 PM
danlee
Feb 16, 2008 08:14 AM
dmkf15079
Nov 5, 2005 03:58 PM
BigBrownTruck
Sep 12, 1999 09:22 AM
