460 efi or carb'd?
Old Oct 20, 2007 | 12:28 PM
kilog55's Avatar
kilog55
460 efi or carb'd?
i can get a 460 from a 90's f250 with efi but is it better to go over to a carb setup? what is involved in switching over? new intake and heads??? not sure if the wiring and brain are intact
Old Oct 22, 2007 | 10:34 AM
mcdonaldm's Avatar
mcdonaldm
yes you have to switch the heads and intake over to a carbed version from efi. the efi heads intake ports won't line up with a carb manifold and i am not aware of anyone making a carb intake for the efi heads.
the only problem you might run into is pushrods. once you have the heads on make or buy an adjustable pushrod to get the correct lenght of pushrods for your combo. Ford changed block heights and head configurations over the years so getting the correct lenght pushrods is mandatory for your combo.
to make your own, take an old pushrod, cut about 1/2" out of the middle, drill and tap the centre for i think a 1/4" bolt (double check that once you have the pushrod cut, it might be bigger or smaller) and you have an adjustable pushrod checker.
rgds
Mike
Old Oct 22, 2007 | 12:21 PM
mustangman's Avatar
mustangman
they make an aluminum adapter plate so you can bolt up a carb right on the efi lower intake,just remove the snorkle efi top intake with the throttlebodies,,,,and drop a duraspark dizzy in ,no more ecm ,efi goes bye bye,,,will need a c6 tranny,other trans need the ecm ,there is probably a way around that too
Old Oct 22, 2007 | 07:54 PM
kilog55's Avatar
kilog55
well i have the 4 speed t-18 so it should work
Old Oct 22, 2007 | 08:03 PM
scottddove's Avatar
scottddove
mustangman how about for a 5.0 efi is there one made to do that with.
Old Oct 23, 2007 | 08:16 AM
darrin1999's Avatar
darrin1999
no but its easier with a 5.0, all you do is swap the plenum for a carb intake. the ports on the heads line up.
Old Oct 25, 2007 | 01:30 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
A carbed set-up will require a distributor with advance weights, springs, and a vacuume advance to control your timing.
info@performancedistributors.com
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributor.htm
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
<O
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
<O
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
jbehuniak
WTB - Parts & other
Jan 18, 2016 03:12 PM
robert.royal
16
Apr 30, 2015 07:02 AM
DieseLife
Feb 28, 2015 01:44 PM
DeenHylton
Mar 19, 2002 10:06 PM
ROUSHRACING
Oct 2, 2001 10:29 PM
