Do be aware that if you are interested in the dually rear axle, it may not fit your truck.
Ford had two frame widths in the mid 80's trucks.
Cab and chassis had a 34" wide frame.
Trucks that left the factory with a bed installed have a 37.5" wide frame.
An axle that runs dual wheels on a 34" frame will not clear the springs with an inner tire on a 37.5" frame and the spring perches on the axle will not line up with the springs.
Your best option to contact SAlexander may be a PM or Email.
He posted in this forum a few times, but I have not seen him here recently.
thanks dave i ran into that problem a couple of times before Ibought a dually rear ror my wrecker (79 350 single wheel) from a75 dually still have adaptors.
I will try that I tried to message him but I am too new a member.
I like your truck like seeing what holds when somebody really uses one mine has easy lives now but they earned it.
