In Cab PC
Old Oct 20, 2007 | 09:26 AM
gigi747's Avatar
gigi747
In Cab PC
I'm thinking about installing a PC [mac mini] in my F250, and wondering if anyone here has done the same to their super duty?
Old Oct 20, 2007 | 09:39 AM
rebelchevy02's Avatar
rebelchevy02
Were going to put a PC base computer in my boss' new duramax truck. We removed his rear seat (extended cab truck) and will be mounting it to the back wall, and a touchscreen up front, what kinda details are you looking for?
Old Oct 20, 2007 | 11:14 AM
nlemerise's Avatar
nlemerise
I have an old Gateway laptop that I use velcro to hold to the center armrest. I use it as a map server with my gps antenna. I can see realtime where I am in a 3-D map (using Delorme TopoMap USA) or I can see where I am on a topomap or air photo, using USAPhotomaps (free). To update USAPhotomaps on the road, I run NetStumbler to find open wifi connections.
Old Oct 20, 2007 | 11:24 AM
bdrummonds's Avatar
bdrummonds
Make sure you have a top notch inverter(not one from wally world) The powersources are very delicate when dirty power goes to them. I had my Think Pad plugged into a inexpensive inverter for a few months and the powersource (inside on the board) was damaged. I was told by my tech people that I needed to run a cleaner inverter. I am sure some of the electronic gurus here will tell you which one. it was either a true sine wave, or a modified sine inverter, I can t remeber. I ended up just going with a long life batt on my laptop and I get 6-8 hrs of work time.
Old Oct 20, 2007 | 11:31 AM
rebelchevy02
This brings up a very good point, a looooong time ago we had trouble with square wave sine inverters (cheaper) and them destroying our cordless drill battery chargers, now the only thing we run is prosine 1k watt and larger units. They are a true sine wave inverter, which means its as good as it gets. They are alot more expensive, but that means you can run anything without fear of destroying its internal power supplies.
Old Oct 20, 2007 | 02:26 PM
SpringerPop's Avatar
SpringerPop
Based on name alone, I bought a Belkin 150-watt for the ThinkPad I recently used on a road trip. It was cheap enough, and played flawlessly.
I know, that's not much of a technical endorsement, and I'd have preferred to have seen the output under load on a scope first, but it worked uneventfully for me.
Pop
Old Oct 20, 2007 | 10:07 PM
sgrol's Avatar
sgrol
check out my gallery for my pc install. I love it and run it with my GPS to know when I get lost. Recently got a wireless aircard so I can access the internet/email while on the road. When I die in a fiery crash, it will be my pc's fault.
Old Oct 21, 2007 | 12:58 AM
Col. Zach's Avatar
Col. Zach
The ideas are great. I had a laptop mounted in my old 1995 f250 that I just traded off. I dont know if I have any pictures of it though.... I do have pics of the mounting brakets I still have them and hope to put them in my new 2000 f350 just havnt had time to as of yet and I want to make some changes to them first... Any one know of a good way to build a swing arm design? Like to make the laptop slide or pivot closer to or a way from you? Like bring it close to type then away to drive or what ever? Thats my goal before I reinstall. Zach
Old Oct 21, 2007 | 08:13 AM
sgrol's Avatar
sgrol
Mine can swivel between driver and passenger but that's about it
Old Oct 21, 2007 | 08:28 AM
Orezona's Avatar
Orezona
Where is the base mounted? Does it run under the flip-down center section to the floor behind the front seat?
Old Oct 21, 2007 | 08:54 AM
sgrol's Avatar
sgrol
it is plywood that sits under the flip down center section and on top of the middle seat. A strap running under the seat and connecting to the front and rear of the plywood holds it down. I think the pics in my gasallery may show this.
Old Oct 21, 2007 | 09:26 AM
Kwikkordead's Avatar
Kwikkordead
I've often wondered why there isn't made a power supply for mobile applications. The motherboards run on 12v and 5v. It makes sense to have a power supply that doesn't use house current in the first place. It could be a very small box because all it has to do is step down the voltage and maybe some sheilding from the alternator, windshield wiper motor noise.
Old Oct 21, 2007 | 12:37 PM
Tecman's Avatar
Tecman
I have a PC built into my truck. I custom built it and it runs off 12V so i dont need to mess with power inverters. Its a small Gigabyte MB with an AMD 2GHtz proc, gig of ram, DSATX power supply that also properly shuts down the PC and powers it up when the cab temp reaches a safe temp. I have a flip out Xenarc touch screen in the dash where i control my music, navigation, internet (for weather reports and fuel prices basically), XM radio, DVDs, AE when I get it, and everything else a PC is capable of. Definately a worthwile investment. The whole thing cost about $1500 and will out feature ANY indash unit on the market. You can also check out www.mp3car.com and they can help with every aspect of your build. They are great people over there. Just make sure you search and do lots of reading before posting.
Old Oct 21, 2007 | 01:05 PM
piotrsko's Avatar
piotrsko
Actually a couple of IC's and some sort of power cooling, BUT the reason for the odd power is because we HAVE to run LI-po batteries and they have wierd charge voltage requirements.
Old Oct 21, 2007 | 01:35 PM
Tecman's Avatar
Tecman
there is alot of options for this
http://store.mp3car.com/category_s/22.htm
