intercooler cleaning help
I'd post a few links for you, but the website is temporarily down right now.
You won't need a parts list because in taking the S/C off to get to the IC, you won't be removing anything that needs replacing. Everything is reusable.
The gasket between SC and midplate is metal and can be reused.
The gasket between the midplate and lower intake manifold is metal and can be reused.
All the bolts are reusable in this area and dont need to be replaced.
DO NOT seperate the IC from the Midplate. Those bolts are torque to yield and cannot be reused, plus you will most likely damage the gasket because it's not metal.
There is no reason to seperate the IC from the midplate in order to clean the IC.
Send me your email, I have the instructions saved to a Word doc I'll send to you in a zipped file.
Stewart
StarGazr9z at aol dot com
Stewart
No problem.
When me and three of my L buddies got together one weekend and held an IC cleaning party, we'd presoak the IC with Easy Off oven cleaner first. Then we'd clean the IC with carb and brake cleaner and compressed air.
This was my IC before cleaning it.
Back of the throttle body.
Underside of S/C.
Valley after IC has been removed.
After its been cleaned.
Stewart
Underside of S/C.
Stewart
Originally Posted by oldiron
I got mine off tonight ( not too bad at all). Mine is nowhere near as dirty as your was (suprising). I can't post pics but I'll send you some is you want.
Thanks for the help
Greg
Thanks for the help
Greg
What year is yours? Mine was a '99 that I bought used with 72K miles on it.
Stewart
John7894
24
02-24-2006 07:54 AM
