Headlight Adjustment
Old Oct 19, 2007 | 03:19 PM
SBrown732's Avatar
SBrown732
Question Headlight Adjustment
The headlights on my 1977 F-100 are out of adjustment (one shines on the road and the other points high). Is there any gauge, tool or procedure to adjust the headlights properly? I know that there are adjustments in the assembly but how do I know what the factory or proper settings are?
As always, thank you for your help.
Old Oct 19, 2007 | 03:24 PM
Mil1ion's Avatar
Mil1ion
It's based on 25 ft and elevation
You need a nice flat surface and a wall to set the headlights.
Googling the words " headlight adjustment " will bring up several hits with instruction
Old Oct 19, 2007 | 04:46 PM
mhg's Avatar
mhg
an easy way to get close is go to a parking lot late at nite
find a level as possible spot near a wall
about 20 feet away and the high beams on
measure to the center of your head lamp
then ajust the beam on the wall to the same height
dr cabela
Aug 7, 2015 04:17 PM
69issofine
Apr 20, 2015 08:58 AM
jbljohn
1983 - 2012 Ranger & B-Series
May 4, 2013 09:02 AM
ohiowhitetail
General Automotive Discussion
Oct 26, 2004 07:32 PM
