If you are trying to correct a poor beam pattern, realize that if your lenses are not crystal clear, you won't get satisfactory light output.
Most polishes and polishing kits do not really work and ruin the lens. They make the lens look nice and shiny and clear, but leave it more vulnerable to damage, so they fade quickly and become harder or even impossible to restore after repeat polishes. Only use polish kits that have a clearcoat stage that coats the lens in a UV blocking protective clearcoat after the polishing process.
