1978 - 1996 Big Bronco
TTB replacement
Old Oct 19, 2007 | 11:57 AM
jstroud08's Avatar
jstroud08
TTB replacement
how hard and expensive is it to replace a TTB with a straight axle
Old Oct 19, 2007 | 10:20 PM
godblessmud's Avatar
godblessmud
That depends on what axle you want, a D44 or D60, and if your doing the work yourself which i'l assume you are.
the Dana 44 (which is what you have the TTB version of) is a straight through swap and a complete axle complete w/hubs and breaks can be found in the 150-400 dollar range. Id start looking for one from a 1977-79 F150 or bronco that is being parted out.
Swapping to a Dana 60 is a whole nother ballgame because either the axle must be converted to coilover springs (they have kits) or your truck must be converted to leaves, not to mention with a stock 8.8 rear end and a swapped D60 you have 5 lugs rear, 8 lugs front. a Dana 60 can be found for 800-1200 dollars complete but are getting harder thanks to all the GM and jeep guys taking ford axles.
surewhynot's Avatar
surewhynot
Its not too difficult, mainly time consuming. It can get expensive depending on your source for parts. Most people go with a dana 44 out of a 78-79. Theres some pics in my gallery of the SAS (straight axle swap) I did on my 94 F150. The ttb on that is the same as your Bronco. Also look for SAS in the offroad forum. Theres alot of good info there.
Old Oct 19, 2007 | 10:57 PM
godblessmud
with the help of a few buddys its easily a one weekend job.
ps. with 33'' tires you'l be fine with the D44
Old Oct 20, 2007 | 01:58 PM
helirich's Avatar
helirich
Surewhynot,
I cant seem to find any pictures in your gallery. Am I doing something wrong?
Old Oct 20, 2007 | 02:10 PM
khadma's Avatar
khadma
Carpenter Local 745
As soon as I finish my Ranger project, I am doing a FSB SAS and I am going to need the experts at FTE to help my through it.
I while ago I drove a 78 F150 4x4 and the steering/contol on that truck was way better than my 88 F150 - I have had several TIBs and TTBs since that time, but I can't wait to drive a truck with a solid front end. (I guess I could by a new 4x4 SD, but where's the fun in that) No I won't buy a Dodge or a Jeep either.
Old Oct 20, 2007 | 04:26 PM
surewhynot's Avatar
surewhynot
Originally Posted by helirich
Surewhynot,
No, I am.
I started changing my gallery around and never finished. Here are some pics.
http://s111.photobucket.com/albums/n...ogress%20pics/
Old Oct 20, 2007 | 07:23 PM
godblessmud
JSstroud, check out the classifieds on this site, there are several people selling Dana 44 straight axles right now.
Old Oct 20, 2007 | 07:38 PM
khadma's Avatar
khadma
Carpenter Local 745
I am glad I found a freebie here. The shipping companies wanted $900.00+ to ship the palleted 400+ pound D44 here.
Old Oct 20, 2007 | 08:10 PM
THE KING's Avatar
THE KING
What did you have to do with the front sway bar? Also what if you have dual front shocks? Do you have to find a straight 44 with the dual shock mount already there? Also What about the radius arms?
Old Oct 20, 2007 | 08:14 PM
surewhynot's Avatar
surewhynot
I extended the links on my swaybar. The dual shockmounts were already on the radius arms that were on the axle I used. They were from a 78-79 Bronco/F150.
Old Oct 20, 2007 | 08:18 PM
THE KING's Avatar
THE KING
The Sway bar on my bronco is different from the ones in your picture. Did you take even the radius arms from the 78-79?
Old Oct 20, 2007 | 08:23 PM
THE KING's Avatar
THE KING
Obviously you did lol i just had to scroll down a little... The truck looks awesome!
Old Oct 20, 2007 | 08:24 PM
surewhynot's Avatar
surewhynot
Yes. The radius arms are from 78-79 as is the sway bar. Sorry for the confusion.
Edit: lol. Thanks!
Old Oct 20, 2007 | 09:20 PM
BEWOLD's Avatar
BEWOLD
[QUOTE=surewhynot]
http://s111.photobucket.com/albums/n146/i_call_me_Tony/94%20progress%20pics/[/QUOTE] Looks good! Is that a firebird on Iroks in the background of the completed photo??
