WHAT IS THIS THING?
Old Jan 17, 2003 | 08:50 AM
sixx pak's Avatar
sixx pak
WHAT IS THIS THING?
[updated:LAST EDITED ON 01-17-03 AT 09:53 AM (EST)]It is on the passenger side, under the hood between the battery and the a/c. It is black,thin and looks like some kind of a blower. It has a hose that runs in from some kind of egr tube and out into the fenderwell connecting to nothing. It has a 2 or 3 wire harness plugged into it.
What is this stuipd looking thing, and can I get rid of it???
Also, if I put the plate in the EGR valve can I get rid of any of this tubing? I have never seen a vehicle with so much emissions junk.
Since I live in Phoenix I do have to get emissions tested, but shouldn't I be able to pass with the cats and an EGR valve on even if it is just there for appearance??
Thanks in advance!
Old Jan 17, 2003 | 09:27 AM
ecarter50's Avatar
ecarter50
WHAT IS THIS THING?
That is the fuel injector cooler. It blows air on the injectors after you shut of the truck.
Old Jan 17, 2003 | 12:31 PM
sixx pak's Avatar
sixx pak
WHAT IS THIS THING?
Interesting...I wonder if mine even works. Anybody ever take theirs off? If so, what were the results?
O.K. so if my air temp here in Phoenix is 115*-120* and the pavement is at least 180*?, combined with engine compartment heat... I'm not sure what the benefits of blowing near 200* air on them is.
Old Jan 17, 2003 | 12:32 PM
cmlind's Avatar
cmlind
WHAT IS THIS THING?
Old Jan 18, 2003 | 06:12 PM
rhetor's Avatar
rhetor
WHAT IS THIS THING?
i think that the injectors will fry much quicker if they don't have the cold fuel running through them to cool them off. Once you turn off the engine, they absorb the heat from the block and fry.
Old Jan 19, 2003 | 08:35 PM
83Steve's Avatar
83Steve
WHAT IS THIS THING?
But that blower was only used on '87-88 4.9Ls - if it's so critical, why didn't '89-96 4.9Ls need it?
Old Jan 19, 2003 | 09:06 PM
rhetor's Avatar
rhetor
WHAT IS THIS THING?
magic elves?
Old Jan 19, 2003 | 09:15 PM
ftwfred's Avatar
ftwfred
WHAT IS THIS THING?
My 1989 F-150 4.9 Litre has one.....It runs most of the summer, After the engine warms up, Runs while driving,
Runs about 30-45 minutes AFTER I shut it off too!!
Old Jan 19, 2003 | 11:32 PM
83Steve's Avatar
83Steve
WHAT IS THIS THING?
OK '87-89. Whatever. It's not on ALL 4.9Ls; certainly not on the '95 in my truck.
Old Jan 20, 2003 | 02:42 PM
MEPR's Avatar
MEPR
WHAT IS THIS THING?
Unless you know exactly what it is and honstly dont think you need it i wouldnt pull it.
