fe question
Old Jul 12, 2000 | 12:19 AM
240Shorty's Avatar
240Shorty
fe question
I have a 1959 edsel with the 352 in it but the only performance parts i can find for 352s are for the ones that came in trucks... what i'm wondering is does anybody know what the difference between the car and truck 352s is, if there is one at all? Thanks
Brian
66 F100 Shortbox I6
Old Jul 12, 2000 | 10:44 AM
FE427TP's Avatar
FE427TP
fe question
if it's a FE pretty much any other FE part will fit as long as it clears the cylinder bores, you should be able to use the edelbrock performer intake with it, and the performer RPM etc...
Old Jul 30, 2000 | 10:51 PM
390fe's Avatar
390fe
fe question
fe427tp is right-anything that will fit a 390 will fit a 352.
Jason
Old Jul 31, 2000 | 07:44 PM
skip4274's Avatar
skip4274
fe question
240Shorty:
Be careful. There is a lot of mix and match with the FE motors. Standard parts CAN interchange; like intakes, heads, cams, crankshafts, blocks, and heads but there are some snags like rod and piston applications that can and will cause you misery. I suggest tryiing to find a copy of "Re-building your Big Block Ford" from Peterson Publishing to make sure things don't bind up. 332, 352 and 360 engines are suspect when it comes to swapping parts. Maybe some of the other posters can specify things for you.
Keep the faith.
Skip4274
4everFord
Old Jul 31, 2000 | 11:29 PM
FE427TP's Avatar
FE427TP
fe question
I second Skip4274's suggestion, buy the book before you tear the engine down, a very good book, and I should have addressed the piston skirt clearance issue
Old Aug 1, 2000 | 11:06 AM
BB's Avatar
BB
fe question
66with352
30
Mar 4, 2018 07:45 PM
66F100Again
Mar 2, 2017 08:53 PM
sixtyfive_ford
Nov 2, 2016 08:48 AM
71mopar383
Jan 19, 2008 10:13 PM
fordmandan
Oct 7, 2001 03:31 PM
