Torque Specs front wheel bearings??
Old Jul 20, 2014 | 01:45 PM
TransBrain's Avatar
TransBrain
I can't access Mitchell on Demand for some reason. Anybody know the proper torque specs for the front wheel bearings?
Old Jul 20, 2014 | 02:12 PM
F250_'s Avatar
F250_
For 2wd, 7-8 inch-lbs.
Tighten to 18 inch-lbs while turning the wheel.
Loosen again.
Re-tighten to the 7-8 inch-lb rating.
Too much tension will cause overheating and will bur up the bearings.
Old Jul 20, 2014 | 03:09 PM
TransBrain's Avatar
TransBrain
Sorry. I should have stated 4x4 hub assy.
My memory is telling me 140ish ft.lbs.
Old Jul 20, 2014 | 04:03 PM
DND58's Avatar
DND58
The 4 studs that hold the hub assembly on are torqued to 133 ft. lbs. per guzzle's procedure.
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Old Jul 20, 2014 | 05:19 PM
TransBrain's Avatar
TransBrain
Thank you.
47 mins to R&R.
This OEM Assy. lasted 18k. Normally get 30-35k.
35 inch tires.
Wife's 2000 Excursion got 85k. Replacements have about 80k. Same year same tires. Weird.
Hers eats brakes mine doesn't.
But I do tow the 4 place enclosed sled trailer. Hers doesn't.
rwrogers
Jan 16, 2014 09:58 PM
2000Ford2000
Sep 21, 2013 07:34 AM
ac700wildcat
Apr 28, 2010 04:24 AM
KennyG228
Nov 25, 2003 06:04 PM
kings51
Sep 11, 2002 12:03 PM
